Box Scraper Box blade for subcompact
/ Box blade for subcompact #1
archerynut
Platinum Member
Near Pittsburgh, PA
Looking again
Still considering which subcompact to buy, but that is another thread. Questions about a box blade.
1. Which size is best for subcompact (Bx24, JD 2305, MF G 2310). I seen 48" and 60". Is there a 54"? Is it best to be a little bit wider than the rear tires.
2. This seems to be the most recommended attachment for many different uses. I want to redo an existing gravel/reground asphault drive. Is this the best for this job.
3. Any brands better than any others. Any features to look for?
/ Box blade for subcompact #2
TSC carries some KK "XB' SCUT implements.. they are cat 1 pin / cat 0 spaced as far as i know. Might check out thire line..
Soundguy
/ Box blade for subcompact #4
I have a BX and the 48" BB works good, I weight it with a steel I beam and concrete blocks, it's reg Cat 1, I can't see paying more for the smaller, lighter XB impliments.
/ Box blade for subcompact #5
Take a look here for answers and comparisions: http://www.tractorbynet.com/forums/...arision-brands.html?highlight=box+blade+photo
Generally a box blade for a sub-compact is lighter, has fewer scarifiers and is not as tall as a box blade for a compact tractor. Often you will see 3 scarifiers on a 48" wide sub-CUT box blade but you'll see 4 scarifiers on a 48" CUT box blade. The scarifiers may not cut as deep on a sub-CUT's box blade either. The logic is simple, sub-CUTs weigh a lot less, therefore they have less traction and consequently can pull less. All that written, if your soil is soft and loose, consider a regular CUT box blade. If you soil is hard, compacted, full of clay or rock, then you might be better off with a smaller sub-CUT box blade.
I like the Mid-West brand, they make a sub-CUT blade.
As for features, that is clearly discussed in the thread I linked above. I would hope that whatever you buy, you post a photo of it to that thread and post your opinoins of the features you like about it to keep it going for everyone's benefit.
Thanks for the link. I did a search and couldn't find any old posts. Hate to rehash things. I will keep updated with pics and reviews. Everyone else feel free to chime in.
/ Box blade for subcompact #7
Woods make an estate series which might fit the Sub Cuts.
KC
/ Box blade for subcompact #8
I have a gearmore 48" regular box blade and I sure wouldn't go any bigger behind my bx23. I don't know why to pay more for the lighter duty sub cut one. Yes it is best to be a little bit wider than the rear tires. I would think it is the right tool to redo your existing gravel/reground asphalt drive. Midwest seems to be popular here. My gearmore looks just like the midwest to me. The heavier the better. The stronger the better.
/ Box blade for subcompact #9
I also have a King Kutter XB that I pull behind my BX1500. I like it a lot. It weighs close to 300 lbs witht the 4 rippers in. I picked mine up for about $350 at TSC. I looked at Woods and a Landpride, but could not bring myself to pay that kind of money for something that I am not using professionally.
/ Box blade for subcompact #10
The Woods Estate Series 48" box blade worked well with my Cub Cadet by MTD 5234D SUB-CUT when the tractor was not in the shop for repairs.
2011 Chevrolet Camaro Coupe (A64194)
2011 Chevrolet...
John Deere Zero Turn Lawnmower (A65579)
John Deere Zero...
Hedge Posts (A65640)
2022 EZ-GO ELITE...
2019 VERMEER LP573XDT LOW PROFILE VACUUM TRAILER (A63276)
2019 VERMEER...
EZ Flow Mod. 300 Gravity Wagon (A66408)
EZ Flow Mod. 300...
