Snow box blade for snow
   / box blade for snow #1
jonsstihl
Quebec, Canada
I just tried out clearing snow with my rear box blade and it really doesn't work that well. I clear with a b7800 and a loader and it works ok but takes a while but with the box blade on the back I can't put the bucket down on float and steer at the same time. to be fair though I didn't try to push the snow in reverse.
my dealer just called and said my puma 64 is in and I hope it won't be the same with the blower. I was hoping to clear the light snow falls with the bucket and blow the pile but I guess I will be using the blower more often.
   / box blade for snow #2
I used a box blade and FEL on my BX2350 last year and it worked ok. I thought the blade did a good job of pushing the snow. This year, however, I bought a front blade and rear blower. It's taking a while to get used to but I think I'll like it.
   / box blade for snow #3
I used a box blade for a few months last year before I found a used rear blade on Craigslist. It worked quite well pushing it in reverse. Granted, my driveway is paved and I was careful to not run into any fixed objects when pushing, lest I damage 3 pt control arms. Obviously not as good as a read blade or better yet snowblower, but it can get the job done in a pinch.
   / box blade for snow #4
I moved out to the acreage just a couple years ago. The first year I tried to use a box blade, did a nice job grading but once it was full it was hard to move the snow away. I ended up with little piles every so often which was a bigger problem - it caught the snow and drifted in. I eventually received my blower and have never tried the blade since.
   / box blade for snow #5
For what its worth, I have had good results using my 7' Bush Hog rear blade for snow plowing. I started out driving forward with the blade reversed so that I didn't dig up the gravel driveway. It worked ok but didn't scrape down to the gravel. Lately, I turned the blade around and shortened the top link so that the blade doesn't dig in. So far it seems to be working fine. I cleans right down to the gravel. I was able to plow the recent 12" snow fall off of my very steep half mile long driveway with no problem.
Adams 6Ton Hydraulic Lime Spreader (A55315)
Adams 6Ton...
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
2021 Ford F-150 4x4 Ext. Cab Pickup Truck (A54814)
2021 Ford F-150...
2015 SKY TRAK 6036 TELEHANDLER (A56129)
2015 SKY TRAK 6036...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
