Grading Box blade for Mahindra 2015
   / Box blade for Mahindra 2015 #1
xcsm
Need opinions on whether a 2015 HST is suitable for operating a 5' box blade or should I choose the 4'. I'll be using the blade for medium landscaping chores. Thanks.
   / Box blade for Mahindra 2015 #3
I run a 5 footer on my 2015 gear. The 4 footer won't clear the width of the tires, if you have r-4s. It handles it just fine.
   / Box blade for Mahindra 2015 #4
I too run a 5-footer on my 2015 4WD (gear). I have no problem pulling a full box of gravel up a steep driveway. I just used it, and the front end loader, to pull about 4 to 5 inches of top soil off about a 60 x 90 foot area that will become a garden area. It was loaded with roots and rocks, and will eventually be put back. I don't think you would be at all disappointed with a 5-foot box blade on the 2015.
   / Box blade for Mahindra 2015 #5
I run a 5' woods on my 2015 HST. Seems to work just right. :)
   / Box blade for Mahindra 2015 #6
I should add that I have loaded tires. I believe that helps alot. Also, when pulling a full box blade, sometimes I'll scoop up a bucket full of dirt for weight on the front. Seems to make a considerable difference.
   / Box blade for Mahindra 2015 #7
A standard duty 5' works fine, but you also have the option with some brands to go 54", just in case you are trying to keep things a little narrower.
Thanks to all. I'll get the 5'.
2008 RIB 24 Cat Boat (A50324)
2008 RIB 24 Cat...
2016 FORD EXPLORER (A51406)
2016 FORD EXPLORER...
TOP HAT TRAILER MFG. LIGHT PLANT TRAILER (A50854)
TOP HAT TRAILER...
PENDING SELLER CONFIRMATIONS (A51219)
PENDING SELLER...
2014 COTTRELL CX-09LS2 AUTO HAULER (A51222)
2014 COTTRELL...
2018 Ford F-450 Crew Cab Knapheide Service Truck (A49461)
2018 Ford F-450...
