Grading Box blade for Mahindra 2015
   / Box blade for Mahindra 2015 #1
xcsm
Need opinions on whether a 2015 HST is suitable for operating a 5' box blade or should I choose the 4'. I'll be using the blade for medium landscaping chores. Thanks.
   / Box blade for Mahindra 2015 #3
I run a 5 footer on my 2015 gear. The 4 footer won't clear the width of the tires, if you have r-4s. It handles it just fine.
   / Box blade for Mahindra 2015 #4
I too run a 5-footer on my 2015 4WD (gear). I have no problem pulling a full box of gravel up a steep driveway. I just used it, and the front end loader, to pull about 4 to 5 inches of top soil off about a 60 x 90 foot area that will become a garden area. It was loaded with roots and rocks, and will eventually be put back. I don't think you would be at all disappointed with a 5-foot box blade on the 2015.
   / Box blade for Mahindra 2015 #5
I run a 5' woods on my 2015 HST. Seems to work just right. :)
   / Box blade for Mahindra 2015 #6
I should add that I have loaded tires. I believe that helps alot. Also, when pulling a full box blade, sometimes I'll scoop up a bucket full of dirt for weight on the front. Seems to make a considerable difference.
   / Box blade for Mahindra 2015 #7
A standard duty 5' works fine, but you also have the option with some brands to go 54", just in case you are trying to keep things a little narrower.
Thanks to all. I'll get the 5'.
Onsite begins 8:30am / Online begins 9:30am (A50121)
Onsite begins...
Backhoe Attachment (A50322)
Backhoe Attachment...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
Ingersoll Rand 2570 Skidloader Breaker (A50774)
Ingersoll Rand...
2000 Ford Ranger (A50515)
2000 Ford Ranger...
Unused 2025 CFG QK16R Mini Excavator (A50322)
Unused 2025 CFG...
