Box blade for a JD 2130?
/ Box blade for a JD 2130? #1
Gloftoe
Austin, TX
None
Anyone have any recommendations for what size/type/manufacturer box blade to get for this tractor?
/ Box blade for a JD 2130? #2
I would recommend an 8' Gannon hd with hydraulic scarifiers. A top and tilt hitch would be a great addition too.
The only hydraulics I have are for the FEL. I don't have any rear remotes (though I'd like to add them one day, but that's another project and expense). Am I correct in assuming any heavy Cat II box blade would work, as long as it's as wide as the rear of the tractor (at the tires)?
/ Box blade for a JD 2130? #4
Yes a 7' or 8' heavy duty box blade will work with your tractor. With your tractor a large rollover box blade could be a good choice too. What ever BB you choose make sure it is rated for 75 hp +. You can buy a Gannon or similar box blade in the 1200 to 1500 lb. weight that will work well with your tractor.
Westerns 8.5 Pro Plus w/Quad, Ultra Mount 2 (A62679)
Westerns 8.5 Pro...
2 Horse Trailer (A62613)
2 Horse Trailer...
2018 DRAGON  130BBL VACUUM TRAILER (A65643)
2018 DRAGON...
2018 DODGE RAM 2500 (A65643)
2018 DODGE RAM...
Spartan RT-HD Zero Turn Mower (A66285)
Spartan RT-HD Zero...
2019 ISUZU NPR 4X2 S/A 20FT BOX TRUCK (A59914)
2019 ISUZU NPR 4X2...
