Box blade for a JD 2130?
/ Box blade for a JD 2130? #1
Gloftoe
Austin, TX
None
Anyone have any recommendations for what size/type/manufacturer box blade to get for this tractor?
/ Box blade for a JD 2130? #2
I would recommend an 8' Gannon hd with hydraulic scarifiers. A top and tilt hitch would be a great addition too.
The only hydraulics I have are for the FEL. I don't have any rear remotes (though I'd like to add them one day, but that's another project and expense). Am I correct in assuming any heavy Cat II box blade would work, as long as it's as wide as the rear of the tractor (at the tires)?
/ Box blade for a JD 2130? #4
Yes a 7' or 8' heavy duty box blade will work with your tractor. With your tractor a large rollover box blade could be a good choice too. What ever BB you choose make sure it is rated for 75 hp +. You can buy a Gannon or similar box blade in the 1200 to 1500 lb. weight that will work well with your tractor.
2016 Peterbilt 579 Wet Kit T/A Day Cab Truck Tractor (A64556)
2016 Peterbilt 579...
2016 Kubota L3301 (A62177)
2016 Kubota L3301...
2016 JOHN DEERE 7210R TRACTOR (A64280)
2016 JOHN DEERE...
7' Pallet Fork Extensions  (A62679)
7' Pallet Fork...
2019 International LT625 Sleeper 48 (A62613)
2019 International...
1143 (A63745)
1143 (A63745)
