Box Scraper box blade for a b7100
/ box blade for a b7100 #1
Illini22
Northern Illinois
2013 Kioti dk40 hst, wright stander zero turn
I'm looking at purchasing a bb for my b7100 4x4 hst with turf tires. I am on info overload with all the posts especially by bob. wealth of info but not tractor specific. I have clay soil, and realize I may have to buy ag tires in addition to the bb. can you suggest the best for the money.
/ box blade for a b7100 #2
With a B7100, I'm guessing you could use a 4 or 5 foot wide model. Others may disagree, but it seems like 90% of the box blades I've ever seen look pretty much the same.
/ box blade for a b7100 #3
Stick to one that is just a little wider than the tractor. The turfs should do fine.:D
/ box blade for a b7100 #4
liledgy:
Welcome to TBN :D! I agree with Egon. Get the heaviest BB for your tractor that your 3PH can lift and if you need traction consider chains. Jay
/ box blade for a b7100 #5
A heavy 4 foot box will work great for you. Your turfs will work on most ground conditions.
Mike
thank you for the replys, I think I will look for a 4 ft heavy blade and some chains. I read that if I get ag tires I would need rims also because they are different sizes?
/ box blade for a b7100 #7
Maybe somebody with a B7100 will offer their thoughts about the chains. I think I'd give it a try without the chains first unless you run up on a set really cheap.
/ box blade for a b7100 #8
I bought a United 4' box blade in the spring for my TC18. This thing is built very well with plenty of weight. If you can find a dealer in you area you should look at one. Take a look at my photo gallery for pics.
Solo
/ box blade for a b7100 #9
Definitely try the box blade without chains but with a loaded bucket. The front wheels add lots of traction. If this proves unsatisfactory try some chains. :D
Do not try 4 link ladder chains as they will be an impossibly rough ride. The two link will be acceptable.:D
/ box blade for a b7100 #10
ok
b7100 iuse 4' box blade and i have new turfs with chains no problems with use i also have had chains off and works well i keep my bucket loaded
I would say go with 4 foot
I wish I had a FEL so I could fill a bucket!
/ box blade for a b7100 #12
Now that should not be too hard. Hang a 5 gallon bucket on the front and fill it with dirt!:D :D :D :D
Egon:D
213120 (A64276)
213120 (A64276)
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2019 KUBOTA KX057-4 EXCAVATOR (A62129)
2019 KUBOTA...
2014 Caterpillar CB54B Articulated Vibratory Tandem Smooth Drum Roller (A61572)
2014 Caterpillar...
2012 Freightliner M2106 Bucket Truck, Terex Hi-Ranger HR52M, 52FT Platform Height (A63689)
2012 Freightliner...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
