Box blade for a 2305
/ Box blade for a 2305 #1
hink10
Bronze Member
Coal Valley, Illinois
John Deere 2305
Hey guys,
I am looking to buy a box blade for my 2305. I have done a bunch of research and it seems the 48" blade would be best suited for the 2305. I am looking at a couple, the Countyline at TSC. It's about a 45 min. drive to my nearest TSC. Also looking at a United at Everything Attachments. Any suggestions? Called on a Frontier at our local JD dealer, would have to order and gave me a price of $883!
Thanks!
Steve
/ Box blade for a 2305 #2
I had a 4010 (18 hp, similar to the 2305) a couple of years ago. A 48" bb worked perfect. It stuck our just an inch or two past the tires. If it got a full bite it would overpower the tractor. You won't be undergunned with a 48" bb for sure.
/ Box blade for a 2305 #3
I have a 2320 with a frontier 2048 on it and it is definitely big enough for the size/hp of the tractor. You wouldn't want to go any bigger unless you're using it without the rippers engaged + using it to spread loose material or removing the rippers & using it for snow removal.
Again, depending on your intended usage, I have found the TSC type stuff to be ok for light-medium duty jobs.
On craigslist I see a lot of better quality, as well as TSC, box blades cheap! I would've definitely bought a used one from CL if I didn't get my 2048 as part of my tractor package.
Good luck.
/ Box blade for a 2305 #4
Hi Steve,
A 48" box blade is just right for the 2305. I have a King Kutter which worked great on my 2305. What are you getting one for? Mine sits a lot, more than all the other attachments, but I know everyone's needs are different.
/ Box blade for a 2305 #5
Agree that 48" is a good match. Frontier used to make a Box Blade for limited cat 1 tracters (BB2048L).
Since the 2305 can't lift as high as bigger tractors, make sure the Box Blade isn't too tall.
I think mine weighs about 300 lbs. and I sometimes add 160 lbs. of weights to get a little better "bite" or to add ballast.
Hi Steve,
You are probably right to go 48", but Landpride makes a 54" that I'm thinking about. The only reason for a 54" is that I plan to add wheel spacers to allow room for tire chains (I have the BH subframe). I am getting the BB for a large project involving a ravine on my property, need to add a bunch of dirt and grade the area for better drainage. I also have areas of my yard that I want to improve in the future, I have about 1.5 acres and a bunch of projects. I have an injured back so manual labor is becoming difficult at best.
That being said, yeah, it may just take up space someday. If that's the case I'll sell it. At any rate, I'm not looking to take big bites of hard soil, in general I'll be moving loose soil. I do have a lot of clay in the soil, but as I said, won't be digging in too much. I can use the loader and BH if I need to.
The cat1 Landpride weighs in at around 400 lbs. They also have a scut model that is smaller and lighter. I may go to the Landpride dealer and have a talk . They also rent equipment, I may see if they have a 60" I can try just to get an idea, I know thats too much for the 2305 but it should give me an idea of what to expect. I don't think they have a 54" or 48" for rental.
I did think about the Frontier but when my dealer gave me the price of $883 I decided against it. I am going to call another dealer as I'm not so impressed with mine, I know I can get a better price.
BTW, how far off the ground can you get your King Kutter in the raised position and how tall is the box? Will a quick hitch give me any additional height?
Thanks!
Steve
/ Box blade for a 2305 #7
Sorry, I can't answer the height question since my 2305 is gone and I've yet to pull the box blade out of the back of the pile:)
Regarding the quick hitch, no, I don't think it will help since the drag arms are directly in line with the two lower clips on the quick hitch. You might be able to get a little more tilt angle, but no more lift, I don't think.
The 54" sounds risky for my own personal limits, but if you do get one, be sure to revisit this thread and let folks know how it works for you!
/ Box blade for a 2305 #8
I have a Cammond 48" boxblade for my x749 and it is IMatch compatible too. Lots of dealers carry this line as it is a little cheaper than the Frontier branded stuff. I think Cammond makes a 54" model also.
Just checked on Cammond's website, I have the BB48 which is 300 lbs, and there is a BB54 which is 325 lbs. I wouldn't think either would be a problem for you as I think the x749 could handle the slight increase in width.
Okay, I'm narrowing it down. I went to my Deere dealer and got a price of $730 for the Frontier 2048L, the lighter version for the SCUT. It has 3 scarifiers and weighs about 275 lbs. I also went to a Landpride dealer. Got a price of $749 for a 54" (BB0554), also the model for the SCUT. It weighs about 300 lbs and has 4 scarifiers as does the Landpride BB0548, the 48" model.
As I believe I said before, thinking about wheel spacers as I have a BH subframe and will use chains in the winter so the 54" would cover my tracks in that case. I think the Frontier and Landpride I have talked about are as big/heavy as I should go according to all the feedback I have received thus far. I am having the Landpride dealer see how long it will take to get a green BB. At This time, I'm thinking the Landpride. Also I understand the full size boxes would not allow much ground clearance with the limited cat1. Any final input would be appreciated.
Thanks,
Steve
/ Box blade for a 2305 #10
I wouldn't think the x749 has more capability to lift higher than a 2305 and I use a full sized 48" boxblade with plenty of lift.
Okay, I have found a JD dealer about 30 miles away that has a BB2048L in stock for $680, not a bad price for the Frontier. I called another JD dealer and he though I could use the BB2060 but ground clearance would be an issue, thought there would only be about 4" from the ground, thought I could gain a few inches with an iMatch, but not ready to buy one yet. He told me he had a used 2305 and he would mount the bb for me to check out. I think I am going to stick with the box blades made for the limited cat 1 with a lower profile blade for clearance issues. I can always add some weight. I have some big jobs to do but not really heavy duty work, light grading etc. What's your opinion on the BB2048L with only 3 scarifiers as opposed to 4 on some others? I'm really leaning toward the frontier BB48L as it's in stock and cheaper than the 48" and 54" landpride 05 series. Oh yeah, it's green too! Are you pleased with the frontier 2048L / 2305 combo?
Thanks!
Steve
/ Box blade for a 2305 #14
Thanks!
Steve
I have been happy with it. (I paid $633 for mine over 6 years ago). I use it for lots of things but when I use it with the 3 teeth extended all the way to break up compacted soil it is possible to stop the tractor.
There are other brands made specifically for limited cat 1 tractors. I think Tractor Supply sells one.
Thanks for the input! I am running out of time to make a decision. I am greatly over thinking as always, but that's not always a bad thing. I want a BB that's quick hitch compatible, I don't think tractor supply is? Anyway it is really dependent upon what's in my area at this point and to be honest, I would kind of like to stay green. It tends to blend better when sitting around. I'm in a residential neighborhood so I want to keep it as subtle as possible.
BTW, do you think the 3 rippers are fine? That was one thing I was concerned about. I don't think I will use them too aggressively, maybe ripping some sod and some light to medium duty soil work.
Thanks again!
Steve
/ Box blade for a 2305 #16
I don't know if you have looked but Woods also makes a line of implements for SCUTs. The Estate series. The 48" box blade is the GBC48.
I have looked online and called about them, my local dealer wanted about as much to order the Woods GBC48 Estate Series as the Frontier BB2048L. Being in stock and the right color makes me lean towards the Frontier.
Thanks,
Steve
/ Box blade for a 2305 #18
hink10,
Here is a picture of the Cammond 48" boxblade that is IMatch ready and green. this is also available in a 54" model as mentioned earlier. The 48" model has 4 shank ripper setup.
First pic of the Frontier LR60L landscape rake.
Second picture is with top link in lengthened position.
Third pic is with top link adjusted midway,
no issues with clearance or lift height imo.
/ Box blade for a 2305 #19
Thanks again!
Steve
I think for normal use that 4 would be somewhat better then three. I used mine which has three to loosen some soil that had been compacted by horses. The soil was hard and dry enough that with three buried it was enough to stop the tractor.
But for driveways and general grading it will pull it easily.
Unless your time is tight, probably not much difference.
So.. another option. I put in a call to a local implements place and just just a message today. He said he has a 48" BB, 60" and much bigger. They are a Bush Hog dealer and show a Bush Hog BB on their site. They are also a Woods dealer, but saw no Woods BBs on the site. In the message he said the were heavy duty but did not state brand. Said the list was $655 on the 48", sell for $575. I don't believe it's the scut model of the Bush Hog by his description. Think it may be the SBX 480, not sure but it looks lie a beast at 430 lbs.
Anyone know what the Bush Hogs price might be? If I can get a good heavy duty BB for over $100 cheaper than the Frontier and not have to drive 90 mile round trip, I may be game. The one issue I see is that on the site they showed a red one, that's one color I'd like to avoid but they do make them powder coated in most major brand colors. To be honest, the color isn't/shouldn't be that big of a deal. They are quick hitch comp. Any input on the Bush Hogs would be appreciated, looking to buy tomorrow.
Thanks,
Steve
6 1/4 INCH OD 90 DEGREE ELBOWS (A68842)
6 1/4 INCH OD 90...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A67714)
GENERAC MOBILE...
2014 MAC FLAMELESS HEATER TRAILER (A67714)
2014 MAC FLAMELESS...
2013 Acura ILX Sedan (A66738)
2013 Acura ILX...
2013 Jeep Wrangler 4X4 SUV (A66738)
2013 Jeep Wrangler...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
