Box Blade Experts, please advise
/ Box Blade Experts, please advise #1
Anonymous Poster
Epic Contributor
I am in the process of looking at box blades for spreading topsoil for a lawn and stone for a long driveway. I believe what I need is a Box blade, I've used them before working for a paver. We used them to level off areas and spread the base (crusher run). I managed to get quite proficient with one, however its been a while.
Do I want a hinged tailgate? I believe that's what we had on the Ford loader I used with the paving company, it provided a better finish with the crusher run and loose materials. I know for seed bed prep a power rake is better, but I can't afford one, and I will most likely buy a tiller and landscape rake in conjunction with these to round out my aresenal. - Same results, more time.
I would greatly appreciate some input, as I've never used a box blade with fixed gate.
/ Box Blade Experts, please advise #2
I am sure no expert but mine has the hinged back and it seems to do a great job on leveling loose dirt. I have no experience in anything but this one. I have attached a link showing my wife blading an area last weekend. You can click through the pictures to see how it finished. (if the link doesn't open on the first try, keep trying..sometimes the site is busy)
<A target="_blank" HREF=http://www.printroom.com/ViewAlbumPhoto.asp?userid=GarageSmoker&album_id=90381&image_id=49>album link</A>
GS
/ Box Blade Experts, please advise #3
While we're on box blades can anyone explain why guage wheels don't come on box blades?? I use them on my rake and use skid shoes on my blade to the same effect. It occurs to me they would be very useful on a box blade also. IE set them for a 2 inch gap, drop the box and drive and you leave a perfect two inch (or whatever) layer of material. I plan on welding some brackets on my box balde so I can use my wheels on it but was wondering if I was missing something.
/ Box Blade Experts, please advise #4
I wouldn't call myself a box blade expert either but once I discovered how to use my hinged rear blade, I got much better.
Yes. You want a hinged rear blade - but one that is lockable. When your rear blade is locked, it will act as kind of a guage wheel. That is, you will be able to lengthen your top link to a point where the rear blade will ride on the just scraped area and hold the front blade at a constant relative height - thus controlling the depth of cut. I don't have position control on my 3ph so this is the only way I can get a consistent depth of cut from one pass to the next.
On the other hand, there will be times you want to take a more agressive cut than the top link adjustment will allow with a fixed rear blade - if you have a lockable one, just un lock it and let it swing.
Finally, if you want to cut and smooth in the same pass, and you have relatively light material (e.g. gravel or fluffy dirt) then by un locking the back blade you can get a less agressive smoothing action from it.
My box blade and I became much better friends when I discovered the versatility of my lockable rear blade.
I have a very old (1978) Gannon box blade.
/ Box Blade Experts, please advise #5
I thought same thing and made a 8' and 10.5' box blade out of 12" I beam on its side.
then put 5' long side rails out of 10" channel on each end
with slots to allow ajustment up and down.
I throw some 1" to 3" blocks under I beam and lock down
sides keep front .5" lower than rear .
Does a VERY nice job of leveling.
Used on driveways, parking lots , and smoothing topsoil in new yards.
/ Box Blade Experts, please advise #6
Sounds like a great way to do large area's. Did you make a frame so you can pick the whole thing up or do you just drag it behind your tractor? Also how big a tractor do you need to pull a 12 foot width if full of loose dirt?
/ Box Blade Experts, please advise #7
Being tighter than Scrooge, I made one out of the tounge off of a mobile home. It came with a jack to use for a gauge. I just added a couple of chains to the open part of the "V" and drag it open end first. Everything gets funneled to the narrow part where the jack sorts em out for size. How close I hook the chains to the drawbar regulates how deep the wide end digs. The lady even paid me for taking the tounges off her double wide. ;^)
/ Box Blade Experts, please advise #8
GarageSmoker,
I looked at all the pics. How can I set up that site and load pics like you did? thnaks, bw
/ Box Blade Experts, please advise #9
Go to WWW.Printroom.com and follow the instructions. Very easy. Just be careful and don't join as a professional because there is a charge. Us amatuers pay nothing for the first 200 MG. which is a heck of a lot of low resolution pictures.
GS
/ Box Blade Experts, please advise #10
I have 3 PT hitch on both.
I did use a L2900 Kubota 4wd w/FEL
Now a NH TC35D
Also works great on JD 250 SSL, I built 3PT adapter that uses
a Speeco quik-tach.
That way I can push or pull it.
Need to get digital pics sometime.
/ Box Blade Experts, please advise #11
Wow, very impressive! I take it from your post that the dirt was loose to begin with..? That's exactly what I'd like to do with my lower field, the one with the crusty soil and the annual crop of rocks. But some of those rocks are pretty big!
Pete
/ Box Blade Experts, please advise #12
Some was but have used box blade and rippers on other jobs.
On driveways have just used just this to tear up and level the center and sides
then spread 411 limestone and roll before paving.
BTW dad has used the 8' on his IH 254 4wd.
/ Box Blade Experts, please advise #13
Florida soil (sand) is pretty loose to begin with. Spent all day yesterday blading the rest of the front. Almost done with the 2nd complete pass. I think I'll do 2 more. than do the landscape rake. Then seed it.
Boy was I dirty! Dust in the air all day.
GS
/ Box Blade Experts, please advise #14
visit me in SC if you want more practice!!!
2016 FREIGHTLINER CASCADIA 125 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 FREIGHTLINER...
3pt 6' Rotary Mower (A64119)
3pt 6' Rotary...
K & F 14" CUT-OFF SAW (A64276)
K & F 14" CUT-OFF...
2021 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2021 Ford F-150...
2007 PETERBILT 340 ROLL OFF TRUCK (A59909)
2007 PETERBILT 340...
2015 Kenworth T680 (A64127)
2015 Kenworth T680...
