jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,787
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
1) Tractor neophytes are usually oblivious to the need for Front End Loader (FEL) counterbalance on the Three Point Hitch.
2) Tractor neophytes are often oblivious to the importance of weight per unit of width when purchasing a Box Blade.
3) A Box Blade is the Three Point Hitch implement most frequently utilized as counterbalance to FEL loads.
I want to develop CORE COMMENT on these inter-related topics.
Application to COMPACT TRACTORS, ie: 12" ground clearance minimum.
(Probably not applicable to Subcompact tractors where few 100 pounds/foot Box Blades are available and "loading" small volume rear tires are not in proportion to heavier tractors.)
This seems fairly universal:
COMPACT TRACTORS >12" ground clearance: Box Blades effective at 100 pounds per foot of width, 120 pounds per foot of width better, 150 pounds per foot of width better-better.
With "loaded" rear tires a Box Blade weight of 120 (+/-) pounds per foot of width is reasonable counterbalance for heavy, not max, FEL lifts.
When rear tires are inflated with air Box Blade weight of 150 (+/-) pounds per foot of width is reasonable counterbalance for heaviest FEL lifts.
Suggested content welcome. Keep it pithy.
pithy ~ adjective ~ 1.(of language or style) concise and forcefully expressive.
synonyms: succinct, terse, concise, compact, short (and sweet), brief, condensed, to the point, epigrammatic, crisp, thumbnail;
The soils I have observed in WV are tough. Box Blades do not cut very well with less thaN 100 pounds weight per foot of width.
Box Blade weight is important as counterbalance to FEL loads when the Backhoe is off. If your rear tires are filled with liquid, 125 pounds per foot of width is about right for counterbalance to FEL loads. If rear tires are filled with air, 150 pounds per foot of width is about right for counterbalance. (For hill work you will likely opt for liquid filled rear tires.)
For an L2501/3301 or L3560 order an implement for Three Point Hitch counterbalance. Box Blade is most frequent choice. I often moont a Cultipacker, which is very compact in size, yet heavy.
LEVERAGE makes a 600 pound counterbalance implement protruding 48" to the rear of tractor more effective counterbalance than 600 pound implement protruding 30".
Few new to tractors realize how much implement weight is transferred to tractor tires, front and rear, through the Three Point Hitch. Fairly obviously, when a mounted implement is raised entirely off the ground, 100% of the implement weight is transferred to the tractor tires.
When implements are drawn by the tractor in ground contact, implement weight transfer to tractor wheels is on the order of 40%; more transiently. Supplying ample implement weight for tractor traction is an important reason to purchase ground contact implements heavy per unit of width, not much wider than rear tires.
Tractor "packages" are notorious for being composed of light, marginally effective, ground contact implements.
Many compact tractor owners utilizing implements as Three Point Hitch counterbalance choose Box Blades.
Box Blades do not cut acceptably, at least for me, until weight is at least 100 pounds per foot of width. My Box Blade is 125 pounds per foot of width. Construction Box Blades are 200 pounds per foot of width or more.
Box Blades of at least 100 pounds per foot of width, and widths of 48", 60", 72" have reasonable weight for counterbalance to general FEL work. One hundred twenty to 150 pounds per foot of width is desirable for counterbalance to HEAVY FEL loads.
Photos 2,3: The sopping wet Water Oak weighed around 1,400 pounds. My Rollover Box Blade weighs 630 pounds.
Tractor's rear wheels were very lightly in ground contact. I should have had a heavier implement on the Three Point Hitch.
Four hundred pounds is enough.
Too much rear weight and the front will lift when you move up a slope with the bucket empty.
Bare tractors are designed with a weight distribution of 40% front, 60% rear.
Add a Front End Loader and the weight distribution becomes 50% front, 50% rear. (+/-)
Fill the bucket and the weight moves forward, leveraged by low-forward position of a laden bucket.
Could be 60% front, 40% rear. (Tractor wheelbase affects weight distribution.)
Rear wheels unlikely to lift from the ground at this moment on level ground, but they will certainly be "light" if bucket payload is wet. Hazardous transporting FEL load over soft or uneven ground.
Green tree trunk sections and laden pallets on pallet forks are often heavier than wet bucket loads. Pallets protrude. Weight distribution could be 70% front, 30% rear. Probability of rear wheels lifting high, pivoting on the relatively weak front axle, which may not be perpendicular to tractor frame.
Conditions for potential tractor rollover.
Suffecient Three Point Hitch counterbalance restores weight distribution to 40% front, 60% rear. (+/-)
Four hundred pounds protruding to the rear seems ample to me.
Rear wheels may or may not lift from the ground at this moment, but they will certainly be "light" if bucket payload is wet.
Green tree trunk sections and laden pallets on pallet forks are often heavier than wet bucket loads. Laden pallets protrude forward. Weight distribution could be 70% front, 30% rear.
Moving dirt is work for a Box Blade with scarifiers.
Box Blades need to weigh 100 pounds per foot of width for this work; 150 pounds per foot of width better. Weight is your friend in ground contact work.
Box Blade needs to be as wide as your rear tires or a bit wider.
Box Blade is the most common implement used as Three Point Hitch counterbalance to FEL loads, ballasting rear of tractor on the ground. Box Blades need to weigh 100 pounds per foot of width to be effective as FEL counterbalance; 150 pounds per foot of width better.
Consider a ROLLOVER Box Blade, pictured, in addition to standard Box Blades.
A stand alone Scarfier will not provide enough counterbalance weight.
With a full bucket of moist soil your rear wheels will rise off the ground, rather than your bucket load. If you get the bucket up and one front wheel drops into a rut or hole, the tractor will roll over.
Center-pivot front axles are weak relative to solid rear axles, where tractor weight is engineered to be carried. If you carry FEL loads without sufficient Three Point Hitch counterbalance is is hard on your front axle and front axle bearings as well as being hazardous.
So, even if you decide to repetitiously move dirt a considerable distance in your FEL bucket you need a heavy Box Blade or another heavy implement mounted on the Three Point Hitch. LONG IMPLEMENTS (Bush Hog, Disc Harrow) soon impinge on tractor maneuverability. Box Blades are fairly compact.
Buy HEAVY once; cry once.
