3-Point Hitch Bouncing three point
   / Bouncing three point #1
mailman02
Carthage MO
ih
My Dk-35 three point bounces when raised with an implement attached. What is the problem?
   / Bouncing three point #2
Bouncing when driving?
Yes, in the up position. When I let it down, it is fine. Sitting in neutral with a six foot brush hog on, it will bounce the front tires
   / Bouncing three point #4
you have a loader on?
   / Bouncing three point #6
you need some front ballast.
Is there an adjustment on the draft control? The manual doesn't show anything.
   / Bouncing three point #8
yes same as the position control but you don't need that to cut.
Ballast can't be an issue be cause it will bounce when sitting still. It has been getting worse. When driving, you can feel it pulse. Also, it depends on which position the third link is in. In the lowest hole, it bounces slowly. In the top hole it bounces fast.
   / Bouncing three point #10
is your draft on?
KJ 23'x22' Double Garage Metal Shed (A50121)
KJ 23'x22' Double...
2012 BMW 528i AWD Sedan (A50324)
2012 BMW 528i AWD...
2020 Ford F-250 Ext. Cab Pickup Truck (A50323)
2020 Ford F-250...
2015 Freightliner M2 106 26FT Box Truck (A50323)
2015 Freightliner...
2012 Ford F-450 Altec AT200A 30FT Bucket Truck (A50323)
2012 Ford F-450...
