3-Point Hitch Bouncing three point
   / Bouncing three point
What do you mean by on? Is it lever position? I usually run it in the down position as I have always done.
   / Bouncing three point #12
It seems your draft is stuck on.imo
   / Bouncing three point #13
The cylinder seal may be shot causing it to constantly drift down and correct itself.
   / Bouncing three point #14
How old is this machine?
   / Bouncing three point #16
raise 3 point with cutter on shut down tractor and post amount of time it takes to fall. Brad may be on to something
I will give that a try. Either cylinder seal or maybe in the valve?
   / Bouncing three point #18
Do you have somewhere to hook a chain up in place of the top link that does not pull on the draft sensing built into the normal top link mounting pin? Somewhere solid on the tractor. That would tell you if it is the draft control or not.
2014 Dodge Charger Sedan (A55973)
2014 Dodge Charger...
2013 Ford Taurus Sedan (A56859)
2013 Ford Taurus...
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2014 Ford F-150 Pickup Truck (A56858)
2014 Ford F-150...
2019 Dodge Charger Sedan (A56859)
2019 Dodge Charger...
2016 Jeep Compass 4X4 Sport (A56859)
2016 Jeep Compass...
