Gale Hawkins
Super Member
- Joined
- Sep 20, 2009
- Messages
- 8,263
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
Separating this from my 3000 CL purchase thread at:
http://www.tractorbynet.com/forums/...s/387255-bought-ford-3000-diesel-today-4.html
Posts #71-74 on this other thread apply to Rusty and not the 1966 3000.
Copy of post #71 in other thread.
Not sure why I bought this one.
We are going to call it Rusty. Actually the motor starts up and sounds awesome to me and with the tractor off the lift would hold up the 5' bush hog without any noticeable seepage 10-15 minutes later. The owner of the last 32 years bought it from the first owner when it was 5 years old. The tach is working and showing 2300 hours and I was told those are its true hours. The brake back plates show some surface rust but at least they are NOT leaking fluid like the 2600 was on the right rear wheel meaning no brake on that side. Actually the sheet metal is very straight for the most part. The power steering control must be leaking some because it is black but nothing is dripping or spraying. The roll bar and single spool controller where added from the owner's brother tractor.
The oil reportedly has been changed every 100 hours and the UTF has been changed out 3 times and the last time was within the last 100 hours of use. The 15W-40 Rotella (oil used last 32 years) looks relative clean.
On the 2600 the guy like to have never got it to start and it ran awful but did smooth out in about 30 minutes but never would take the gas without a hesitation. Brought back bad carb memories but having to dry up the rear seals leaks for the new 40 years just did not appeal to me.
At least I have a project tractor that it will be hard to hurt its looks.
