Rotary Cutter Bought myself a rotary cutter
   / Bought myself a rotary cutter #1
STx
Bandera, Tx
New Holland TC40 DA, Deere 17D, Hyster SX50 forklift, Case D450, Kubota ZD1011-54, International Dump Truck, Kubota SVL-952S, Volovo EC250DL
I think I got a pretty good deal, Rhino TW72, probably a 2002 - 2003 model based on the serial number for $1,000. There are some dents and dings in the deck and there's been some welding done on the rear deflector over the years but otherwise she seems to be in pretty good shape.
Ran quietly, no rust under the deck, brand new tail wheel and still a good bit of steel on the blades. Can't wait to get back to the property next weekend and start shredding some new trails now that I can get equipment across the creek.
I definitely need a bigger trailer now though, I'm thinking a 25' dovetailed goose neck with a pair 10k axles should do the trick...
   / Bought myself a rotary cutter #2
Looks like a nice cutter, and yes I think you are going to need a bigger trailer.
   / Bought myself a rotary cutter #3
I have an older Rhino 6ft cutter. I think they are well built and very durable. Chain guards on the front are also a great addition. I built a chain guard for my 10' cutter. NEVER get any debris forward. Good thing...
Couple of pics unloading it and hooked up. I love the extendable 3pt links on this tractor, they make implement hookup almost pleasant.
   / Bought myself a rotary cutter #5
She's a Beaut!!! Tractor and cutter!!!
   / Bought myself a rotary cutter #6
Looks like a new tire and paint. I am sure she will do a lot of work for you.
   / Bought myself a rotary cutter #7
Nice tractor. Just curious - what would that attachment cost brand new?
Yes it is new paint and a new tail wheel.
I was quoted about $2700 for a 72" Land Pride with slip clutch. This one is definitely much heavier built with 10ga steel on the deck and 1/4" thick sides, it's a very sturdy cutter. I haven't priced the Rhino new but all the other used Rhino cutters I saw were $1400 minimum. I think new, this one would have been close to the price of the Land Pride, if not a little more.
   / Bought myself a rotary cutter #9
In my territory used cutters are common. And are usually a bargain.
   / Bought myself a rotary cutter #10
It appears to be built like a tank. Sounds like you got a good deal.
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
Greenworks Commercial 82V CZ60R Zero-Turn Mower- BRAND NEW, NEVER USED (A52748)
Greenworks...
New 40ft High Cube 6 Door Container (A53002)
New 40ft High Cube...
2001 Blue Bird Commercial Portable Office Bus (A51692)
2001 Blue Bird...
2013 FORD F-650 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 FORD F-650...
