Bought an MTL Root grapple
   / Bought an MTL Root grapple #11
I bought the RK5 rock, root grapple. Weighs at least 500 lbs. It would be better suited for a much larger tractor than I have. I thought the closer bottom tines would help with some of the smaller debris.
I can use it but I can't get it to penetrate a pile with wet dirt. When I do my loader won't lift it. I have verified my loader will lift 1200 lbs plus the bucket and forks. I didn't test for height but I was moving my diesel generator with it.
Not sure if I will continue to use it as is, sell it, or take the plasma cutter to it. I am thinking about using a circle magnet as a guide and cut a bunch of holes in it.
   / Bought an MTL Root grapple #12
I just picked up a 48" root grapple from MTL on Friday. Ordered my diverter kit yesterday, ships today.
I can't wait to use this thing. I have cleared and am in the process of clearing some land and I think this thing is going to be invaluable getting everything piled up. Can't wait to use it!!
   / Bought an MTL Root grapple #13
Probably not worth the effort. For example- 50 holes, 2" diameter, thru 3/8 steel would save 17 lbs.
   / Bought an MTL Root grapple #14
I will take your word for it. I will probably stick with the use it as is option. I moved a bunch of stumps with it yesterday and it handles most of what I would need. I have to do everything in slow motion and be careful. I picked up one large one off center and the tractor leaned pretty bad so I dropped it and got center on it. I have my front tires set in the wide position and the rears are new wheels with a bigger offset than what came on it. The rear track is 6 inches wider than the stock wheels were in the wide setting.
   / Bought an MTL Root grapple #16
I bought a 66 inch MTL Grapple for my 50 HP Mahindra. It took me a while to figure out the third function. At first I was going to install but changed to letting the dealer do it. They knew way more about it than I did and their method was much cleaner than my plan.
I used it for the first time this last weekend. Works pretty dang good. I have the one with dual chompers for lack of better terms. The dealer even commented saying that was a pretty good grapple for 1000 bucks. He said many do not have cover for the Cylinders which the MTL does.
For my weekend stuff, it does plenty good. I am very pleased.
Now i just need to get a Woodland Stump Grinder, Forklift attachment and a few other items!!!
   / Bought an MTL Root grapple #17
Got it today, everything looks good, welds and finish work are decent, good penetration and flat, only thing that stuck out was the finish is almost non existent up underneath.
Supposedly powdercoated.
Its gonna get used.
I have seen the ovens they are powder coated in. I can assure you that you were not misled.
Mine has been holding up great for my use!
   / Bought an MTL Root grapple #18
Im still happy with my MTL 66 dual lid. Its picked up everything Ive wanted it too and saved my back a lot of hurt. The $ i saved buying it over other brands paid for my 3rd function kit.
   / Bought an MTL Root grapple #19
I bought the same dual lid and same here. What I saved paid for my third function or at least a good part of it. For weekend stuff 1000 buck grapple is hard to beat
NEW Wolverine Skid Steer Auger Drive And Bit (A59000)
NEW Wolverine Skid...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
2022 Horizon (A55973)
2014 Ford Fusion SE Sedan (A55758)
2014 Ford Fusion...
2018 VOLVO VNL TANDEM AXLE SLEEPER (A58018)
2018 VOLVO VNL...
