CliffordK
- Joined
- Mar 8, 2013
- Messages
- 2,421
- Location
- Eugene, Oregon
- Tractor
- Toro D200, Ford 1715, International 884,
The tines still have a lot of yellow paint on them, and from what I can see look relatively square, so the hours are low. Even fresh paint won't hide badly worn tines. The tiller has had some weather damage with more paint loss form rust than actual use.From the looks of it, I'd say it was 5 or 6 VERY HARD HOURS....
Yeah, looking at the paint, it looks not much better than my 22 year old tiller that I’ve used annually.
If painted, then wire brush cleaned, the discoloration would be gone.EXACTLY. No heat discoloration on the parent metal and to obtain a huge weld bead like that, there would be. There is none. Not welded at all.
How many Horsepower for that tractor/tiller? It looks pretty large.
That joint would naturally be a tough joint to weld. One of the reasons I started stick welding. MORE POWER!!!
First of all, the sleeve should be a very tight fit on the shaft, and everything should be very very straight. Any looseness of the sleeve, or wobble in the shaft would be a weak spot. Is it a through shaft, or just a stub?
However, the large shaft is a huge heat sink. One needs to push a lot of heat into the shaft, then just barely touch the weld to the sleeve to not burn it away.
If the back side of the flange is accessible, I'd probably also weld the back side of the flange to the shaft, and figure out how to shape the other parts to not grind away my weld.
Hopefully that tiller is designed to be repairable, and not just welded into one solid block.
