RobertBrown
Elite Member
90 p.s.i.Gave the spring and rails a squirt of WD-40 and that solved the feeding problem.
If I adjust the depth wheel all the way to the deep end, it will sink the toenails almost flush, but not quite. Maybe I need to up the pressure some. I'm running about 90psi. Range in the manual is 70-120.
What pressure do you guys run your guns at?
Ian
