Bought a couple of surplus generators
   / Bought a couple of surplus generators #1
Number15
Rhea County TN
AC 7600 TTR, Branson 5520CH, Grasshopper 928D2
Just purchased 2 MEP-802a generators. I threw out a low bid on them not expecting to win, bur low and behold I won both :)
So now one will go on my new shop and I will probably try and sell the other because I need a bigger one for the house. Even though this would work in a pinch.
Both had level 2 resets, 1 in 2015 and 1 in 2016 and then they went into storage. Both had ~2 hours on the rebuild. I am going to repurpose the trailers eventually.
Here is one of them firing up. This is first start after new batteries and to my surprise it fired right up
All gauges work and generator is putting out correct voltage on all legs
   / Bought a couple of surplus generators #3
How many watts are they? What do they run on? Look very cool.
   / Bought a couple of surplus generators #4
I'd bid on them also. If you got them for a good price.....👍
   / Bought a couple of surplus generators #5
5K Diesel
Prepper and surplus sites out there have them listed at $3500 and up without the trailers which is a stupid high price for such a low output.
Curious what kind of low bid won though.
   / Bought a couple of surplus generators #6
I would have bid on them also if not just for the running gear, it sounds good. Seems like a low output for such a size machine tho............Mike
   / Bought a couple of surplus generators #7
Are they 3 phase? Most surplus gens are 3 phase and some can be goofy voltages.
   / Bought a couple of surplus generators #8
^^^ From one of the mil surplus sites ....
This model MEP-802A is a highly durable, battlefield ready generator. It is the perfect size for so many applications. The photos are representative of the actual generator you will get, but it will look very similar. All have very low hours (less than 100), which indicates they were only ran for maintenance purposes. NSN# 6115-01-274-7387.
Model: MEP-802A
Voltage (Volts): 120/208/240
Frequency (Hz): 60
Speed (RPM): 1800
Phase: 1 and 3
FUEL:
Fuel Capacity (Gal): 5
Fuel Consumption (GPH): .57
Fuel Requirement: Diesel/JP-8
ENGINE:
Manufacturer: Onan
Model: DN2M
Type: Cylinders: 2 Cycle
Displacement: 57 in3 (0.9L)
Audio Rating: 70dBA @ 7 meters
DIMENSIONS:
Length (in): 50.4
Width (in): 31.8
Height (in): 36.2
Dry Weight (lbs): 800
Wet Weight (coolant & POLs): 888
That's without the trailer.
I think the trailer might be more useful to many.
   / Bought a couple of surplus generators #9
I wouldn't mind having one opf those. What site do you guys use?
   / Bought a couple of surplus generators #10
Great score!
Frequent power outages have thought about the same. 4 hour outage from storm yesterday. Trying to get the gumption to clear the trees from driveway this morning.
Those trailers are great. Use a similar one for the farm. Hydraulic and hand mechanical brakes are great with the tractor.
PM me if you decide to sell one. Go big orange
2020 Case 5550 Trident (A56435)
2020 Case 5550...
Fork and Frame Skid Steer Attachment (A56857)
Fork and Frame...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
Butterfly Artwork (A55758)
Butterfly Artwork...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
207010 (A55853)
207010 (A55853)
