Bought 3525 any tips?
/ Bought 3525 any tips? #1
JHFV
ENNIS TEXAS
mahindra 3525
Well my new 3525 will be delivered today. First up mow the pasture. The grass is about 18" high. What gear to mow in and what pto speed? I have a 6ft mower. Any other things to look out for?
/ Bought 3525 any tips? #3
I am happy for you, hope you enjoy your 3525 as much as i do mine. On your tachometer there is a little sign to tell you how fast to run your pto, as for what gear to mow in i don't know. Don't be fooled by the 35 horse motor, that is a very heavy and powerful machine be careful and enjoy.
/ Bought 3525 any tips? #4
/ Bought 3525 any tips? #5
I just flung a 15lb rock about 25 yards with a mower.
Be careful. Good luck.
/ Bought 3525 any tips? #6
/ Bought 3525 any tips? #7
If your 3525 is brand new (read 0 hours), suggest you break it in by the book. I think it will tell you to not run the engine without load. I broke my 6000 in with a 7 ft rotary in 3-4 foot pasture grass. I kept it about 1500 rpm (2000 rpm is pto speed of 540) in 3rd gear (of 8 forward). I wanted to keep the engine under some load but not full revs it untill it had some break in hours on it. I varied the speed by 100 or so rpm up and down as I went. The 6000 has so much torque that I have never had to use this machine at over 1800 rpm for anything. I choose the right gear so it doesn't "lug". I cut now in 4th gear at about 1700-1800 rpm. Good luck with new tractor and let us know how it works out! BobG in VA
/ Bought 3525 any tips? #8
/ Bought 3525 any tips? #9
Number one tip: secure the drawbar. You don't need it while mowing and it can and will shake lose and fall off. Don't ask me how I know this. Check all bolts after a few hours of operation especially the ones holding the sway link brackets to the axles. With a 6 ft mower and 18" grass your 3525 will not know there is an implement attached. Your 3525 is a fine tractor and the longer you have it the more you will like it.
Jim
/ Bought 3525 any tips? #10
Jim
/ Bought 3525 any tips? #11
I have a 3525 with 175 hours. I have a 6 foot cutter. I usually run in low 4 and it looks good when finished.
/ Bought 3525 any tips? #12
More info coming soon (A61569)
More info coming...
16ft T/A Utility Trailer (A64557)
16ft T/A Utility...
2014 KENWORTH T370 ROAD TRACTOR (A65054)
2014 KENWORTH T370...
2014 UTILITY 53X102 DRY VAN TRAILER (A59914)
2014 UTILITY...
60ft. Truck Auger (A65640)
60ft. Truck Auger...
2008 Toyota Camry Sedan (A61574)
2008 Toyota Camry...
