Bore scopes
/ Bore scopes #1
Hooked_on_HP
Coal City IL
Ford 1900 FWD Kubota F2100E
I am wanting to buy a bore scope and was wondering if anyone could recomend an affordable one. Is there any to stay away from. What specifications should I look for.
Bill
/ Bore scopes
I want to be able to look in the bores and lifter area of my race engine. And also thought it would be good at work for finding where oil leaks are comming from when you cant get your head close enough to see.
Bill
/ Bore scopes #6
I wonder if that is the same camera my doctor used for my colonoscophy. Vaseline optional. plowking
/ Bore scopes #7
Here is one I have, cheap but got me out of a few jams!
/ Bore scopes #8
G'day i use a snap on one at work and find it very good 8 mm head on it and adjustable brightness along with a mirror that slips on the end of it to see at 90deg to the camera. You guys have prob got a better range to choose from over there we are fairly limited here with what is available good luck they are a handy tool:)
/ Bore scopes #9
Bill
Take a look at the Ridgid see snake.
2014 GULF STREAM TRAILMASTER (A67714)
2014 GULF STREAM...
GENERAC MOBILE PRODUCTS  MTL6S (INOPERABLE) (A68842)
GENERAC MOBILE...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
Unused 2021 NM 2HD-18 18in. Bucket w/ Teeth Excavator Attachment (A66734)
Unused 2021 NM...
2012 FORD F-550 SUPER DUTY (A67714)
2012 FORD F-550...
