Boom cylinder specs
   / Boom cylinder specs #1
rodeogirl07
2014 new holland boomer 24
Hello everyone,
I'm in desperate need of help. I have been trying to find the specs (stroke, extended and retracted) for a boom cylinder on a 235tl loader that's on a new holland boomer 24. I have called multiple dealers and they have the part just not the specs. And I really dont want to buy a new cylinder from dealer as it is 700 bucks. Does anyone have the specs or know where I can get them...please help. Thanks in advance.
   / Boom cylinder specs #2
I'd have it rebuilt at a hydraulic shop, that would be the cheapest. If it can't be rebuilt, they'll be able to sell you an equivalent cylinder.
My husband and I measured the other cylinder that matches the bad one. I did take the bad cylinder to a hydraulic shop and to get it rebuilt is gonna cost close to 700 which is the same cost as a new one thru new holland. I did find cylinders thru magister that I think will work and have matching specs for retracted measurement but they are out of stock at the moment.
   / Boom cylinder specs #7
Why was it so much to rebuild? Does it have a bent or scored rod? or a scored bore?
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
2005 GENIE Z-34/22 ELECTRIC TELESCOPIC MANLIFT (A51246)
2005 GENIE Z-34/22...
378813 (A51573)
378813 (A51573)
TOSHIBA 8000 BTU WINDOW AC UNIT (A51248)
TOSHIBA 8000 BTU...
HAMM 3205 SMOOTH DRUM ROLLER (A51242)
HAMM 3205 SMOOTH...
