Boom cylinder specs
/ Boom cylinder specs #1
rodeogirl07
2014 new holland boomer 24
Hello everyone,
I'm in desperate need of help. I have been trying to find the specs (stroke, extended and retracted) for a boom cylinder on a 235tl loader that's on a new holland boomer 24. I have called multiple dealers and they have the part just not the specs. And I really dont want to buy a new cylinder from dealer as it is 700 bucks. Does anyone have the specs or know where I can get them...please help. Thanks in advance.
/ Boom cylinder specs #2
I'd have it rebuilt at a hydraulic shop, that would be the cheapest. If it can't be rebuilt, they'll be able to sell you an equivalent cylinder.
/ Boom cylinder specs #4
...(stroke, extended and retracted)...
Can you remove it from the tractor? Then manually extend and retract it, to measure the distance... Are they bent? or just leaking? I would also, recommend to find a hydraulic shop. Ask others around you to where you should go.
My husband and I measured the other cylinder that matches the bad one. I did take the bad cylinder to a hydraulic shop and to get it rebuilt is gonna cost close to 700 which is the same cost as a new one thru new holland. I did find cylinders thru magister that I think will work and have matching specs for retracted measurement but they are out of stock at the moment.
/ Boom cylinder specs #7
Why was it so much to rebuild? Does it have a bent or scored rod? or a scored bore?
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2016 International WorkStar 7500 T/A Dump Truck (A61573)
2016 International...
2014 Toro Z-Master 6000 Series 60in Zero Turn Commercial Mower (A59228)
2014 Toro Z-Master...
2016 Dodge Charger Sedan (A61574)
2016 Dodge Charger...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
2014 Ford E-250 Cargo Van (A61573)
2014 Ford E-250...
