Boom cylinder specs
/ Boom cylinder specs #1
rodeogirl07
2014 new holland boomer 24
Hello everyone,
I'm in desperate need of help. I have been trying to find the specs (stroke, extended and retracted) for a boom cylinder on a 235tl loader that's on a new holland boomer 24. I have called multiple dealers and they have the part just not the specs. And I really dont want to buy a new cylinder from dealer as it is 700 bucks. Does anyone have the specs or know where I can get them...please help. Thanks in advance.
/ Boom cylinder specs #2
I'd have it rebuilt at a hydraulic shop, that would be the cheapest. If it can't be rebuilt, they'll be able to sell you an equivalent cylinder.
/ Boom cylinder specs #4
...(stroke, extended and retracted)...
Can you remove it from the tractor? Then manually extend and retract it, to measure the distance... Are they bent? or just leaking? I would also, recommend to find a hydraulic shop. Ask others around you to where you should go.
My husband and I measured the other cylinder that matches the bad one. I did take the bad cylinder to a hydraulic shop and to get it rebuilt is gonna cost close to 700 which is the same cost as a new one thru new holland. I did find cylinders thru magister that I think will work and have matching specs for retracted measurement but they are out of stock at the moment.
/ Boom cylinder specs #7
Why was it so much to rebuild? Does it have a bent or scored rod? or a scored bore?
Case IH 5100 (A64119)
2022 EZ-GO ELITE...
2019 Mack Granite Tri-Axle Dump w/ Lift Gate 006043 (A62613)
2019 Mack Granite...
FORD SUPER DUTY TAILGATE (A64281)
FORD SUPER DUTY...
2020 International HX620 Quint Dump (A62613)
2020 International...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
