Boom and Bucket Tilt slowly fall on Bobcat
   / Boom and Bucket Tilt slowly fall on Bobcat #1
dieselfuelonly
Chapel Hill, North Carolina
Yanmar YM1401D
Hey ya'll, I know this forum doesn't deal with skid steers as much as it does tractors, but I was hoping someone could help me with an issue I'm having with my 2000 Bobcat 753.
I recently had the hydraulic control valve rebuilt and reinstalled it in the machine.
When the machine is operating, both the boom and bucket tilt slowly fall down. If I pick up on the seat bar or shut the engine off, they immediately stop. However, there is still a little "play" that you can move the cylinders a tiny bit, and when I move them into the upper range of that "play", they don't fall back down again. I don't think its the seals in the cylinders. They weren't causing problems before the control valve got rebuilt.
I have misplaced both of my auxiliary solenoids, so I don't have those connected. I was told it was fine to run without them.
I know there are many issues that could cause this problem, but I'd first like to start out by making sure I have reconnected all the hydraulic lines and solenoids to the electrical harness correctly.
Does anyone have a Bobcat that is somewhat similar to mine (mine has the BICS valve on top of the control valve) that would be willing to pop the cab and take a couple pictures?
I'd REALLY appreciate the help, the closest dealer is 45 minutes away, and my service manual and other internet resources haven't been much help.
Thanks,
Dennis
   / Boom and Bucket Tilt slowly fall on Bobcat #2
Are the levers actually going back to neutral when you release them. Is it doing the same thing it did before you had them rebuilt. Did they run a test on the valve after they rebuilt it.
Yeah, the pedals are going back to center. It didn't do this before I had the control valve rebuilt.
I'm not sure if they ran a test on it or not - I just took the valve to them, not the whole machine.
   / Boom and Bucket Tilt slowly fall on Bobcat #4
dieselfuelonly, Did you ever figure this out. I have the exact same problem.​
UNUSED JCT 84" HYD DOZER BLADE (A51248)
UNUSED JCT 84" HYD...
UNUSED CFG INDUSTRIAL QK16R EXCAVATOR (A51247)
UNUSED CFG...
(INOP) JLG 36AM-DC VERTICAL MANLIFT (A51247)
(INOP) JLG 36AM-DC...
Landoll Hauloll (A53473)
Landoll Hauloll...
2016 J&M 1122-20T X-Tended Grain Cart (A50657)
2016 J&M 1122-20T...
UNUSED FUTURE FT850J SMOOTH DOUBLE DRUM ROLLER (A51247)
UNUSED FUTURE...
