Bolt on hooks
   / Bolt on hooks #13
40,000 pound D rings are like $7 on amazon. Why screw around with a 300 pound d ring that isn’t big enough to fit a chain hook through? I make max loader capacity lifts in the center of my bucket all the time, but it’s a heavier duty bucket. I think I would throw some angle iron across that bucket first.
   / Bolt on hooks #14
He's asking about LIFTING 300lbs, not using a 300lb capacity D-Ring.
   / Bolt on hooks #16
I weigh 300 lbs. I wouldn’t hesitate to stand (or jump up an down) on the center of that bucket. At long as the ring is properly attached, it will be fine.
   / Bolt on hooks #17
I like lifting with the chain across both hooks so the loader arms are lifting with both sides.
   / Bolt on hooks #18
Which is why I put a hook in the center.
   / Bolt on hooks #19
I have a receiver in the middle of my bucket and two bolt on hooks inline with the loader arms. I put a 1/4" x 4" backing plate all the way across inside the bucket. All six bolts go thru this plate to reinforce the top of the bucket. My little tractor only has an 1100 pound lift capacity but better safe than sorry.
RSKY
   / Bolt on hooks #20
One on each side is good enough for me.. When I had a bigger tractor I had three hooks welded to a plate that went the length of the bucket for support but I use my pallet forks for most of my lifting these days..
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2014 Ford F-150 4X4 Ext. Cab Pickup Truck (A53422)
2014 Ford F-150...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2014 Kubota M8560D (A53317)
2014 Kubota M8560D...
2023 Bobcat T66 Two Speed Compact Track Loader Skid Steer (A55851)
2023 Bobcat T66...
Kawasaki Brute 800 ATV (A55853)
Kawasaki Brute 800...
