Bolt on hooks
   / Bolt on hooks #13
40,000 pound D rings are like $7 on amazon. Why screw around with a 300 pound d ring that isn’t big enough to fit a chain hook through? I make max loader capacity lifts in the center of my bucket all the time, but it’s a heavier duty bucket. I think I would throw some angle iron across that bucket first.
   / Bolt on hooks #14
He's asking about LIFTING 300lbs, not using a 300lb capacity D-Ring.
   / Bolt on hooks #16
I weigh 300 lbs. I wouldn’t hesitate to stand (or jump up an down) on the center of that bucket. At long as the ring is properly attached, it will be fine.
   / Bolt on hooks #17
I like lifting with the chain across both hooks so the loader arms are lifting with both sides.
   / Bolt on hooks #18
Which is why I put a hook in the center.
   / Bolt on hooks #19
I have a receiver in the middle of my bucket and two bolt on hooks inline with the loader arms. I put a 1/4" x 4" backing plate all the way across inside the bucket. All six bolts go thru this plate to reinforce the top of the bucket. My little tractor only has an 1100 pound lift capacity but better safe than sorry.
RSKY
   / Bolt on hooks #20
One on each side is good enough for me.. When I had a bigger tractor I had three hooks welded to a plate that went the length of the bucket for support but I use my pallet forks for most of my lifting these days..
2018 MDB T5E MDB DISC MOWER (A51406)
2018 MDB T5E MDB...
1643 (A57192)
1643 (A57192)
2015 Ford Transit 250 Cargo Van (A55852)
2015 Ford Transit...
2012 KENWORTH T660 ROAD TRACTOR (A52706)
2012 KENWORTH T660...
2024 CHEVROLET SILVERADO 2500 HD BED (A57880)
2024 CHEVROLET...
25 DUAL AXLE GOOSENECK TRAILER (A55745)
25 DUAL AXLE...
