Front-End Loader Bolt-on Hook for FEL
   / Bolt-on Hook for FEL #21
Try a local salvage yard and take a couple off the front of a GM 4X4 truck.
   / Bolt-on Hook for FEL #23
"T" Hooks & Forged hooks, See pictures.
Most of the time I like and use Grab Hooks with a chain. That prevents loads from sliding around. Also I make almost everything needed or wanted.
The hooks on the top of my bucket are hand forged out of RR Spikes. Before you bad mouth RR spikes as poor metal, they are a little harder than mild steel, better than most "Cast Steel" and some Stamped or forged hooks. They have also stood the test of time & load. On an up pull they are strong enough to lift the back wheels off the ground.
They could have been forged to Bolt on, but then you are dealing with bolt strength. Welding to a plate and bolting it on is a good option, just use a good grade of bolt and 2 or more.
"T" Hooks are good for a moderate load and can be had with different load rating. They will work best on the ends of the bucket instead of the top. I have looked them up on the net and could not find any that came with a "hook" all had loops on them. Buy hooks seperate, cut the loop and re weld it. Cut a "keyhole" slot that the T just fits into. I use them fairly often on the back hoe bucket for modest loads. If your bucket is on the thin side Weld on a steel plate for the keyhole.
   / Bolt-on Hook for FEL #24
JB4310 said:
This is what I suggest whenever this subject comes up.
JB.
Where did you find that bolt on receiver ? Looks like a good idea.
UNUSED 70PCS Grey Metal Roof Panels (A53117)
UNUSED 70PCS Grey...
2013 Infiniti JX35 SUV (A55853)
2013 Infiniti JX35...
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
VERMEER RTX 130 WALK BEHIND TRENCHER (A51242)
VERMEER RTX 130...
2016 Ford E-450 LP Handicapped Bus (A53422)
2016 Ford E-450 LP...
