Bolt on chain hooks
/ Bolt on chain hooks #1
CraigM
Golden, IL
B2150HSD, JD3020
Does anyone know where I can get a few bolt on chain hooks? Weld on would be ok too. I want to put a few hooks on my FEL.
/ Bolt on chain hooks #3
Many other threads on this but AW Direct is a great group to work with. I recently purchased weldable hooks from them and I highly recommend them. The seem to be the consensus favorite.
/ Bolt on chain hooks #4
I saw that they have different sized hooks. Is there any concensus as to which size works the best?
/ Bolt on chain hooks #5
Depends on the size chain you have, but I like the 3/8 grab hooks. They will also hold 5/16 chain...I don't know if that is recommended, but it seems to work for me.
I have both 3/8 and 5/16 chains so using the 3/8 grab hooks made sense to me.
/ Bolt on chain hooks #6
I got the same size hooks (from AWDirect) for the same reason. I figure if I need my 1/2" chain, I'll wrap it around my bucket. /forums/images/graemlins/grin.gif
/ Bolt on chain hooks #7
If u need 1/2" chain u better get more than a CUT /forums/images/graemlins/grin.gif
Thanks for the link.
/ Bolt on chain hooks #9
I just got some tow hooks at TSC drilled holes and
bolted them on. Very handy See attached picture.
/ Bolt on chain hooks #10
<font color="blue"> If u need 1/2" chain u better get more than a CUT </font>
You make a good point. As I think about it, I might need 1/2" with my CUT, but only to pull it out of somewhere I wish I hadn't gone. /forums/images/graemlins/blush.gif /forums/images/graemlins/wink.gif /forums/images/graemlins/smile.gif /forums/images/graemlins/grin.gif
/ Bolt on chain hooks #11
k4hal,
I did that too and they are handy. Mine are bolted back further on the bucket on a large sheetmetal surface that is not as well supported as where yours is. Somewhere along the line, probably when picking up a large centered load, it put enough side force on those hooks to bend the sheetmetal they are mounted on. (~3/16 inch thick) I'd like to find some of those with a wider mounting surface.
John
/ Bolt on chain hooks #12
I bolted on a pair of 1 foot long chain loops on either side of my bucket. I used half inch chain thru 12MM thru the mounting setup I assume was for pallet forks or some other bucket addon. My bucket came from the factory with a 12MM nut welded to the top of the bucket on each corner.
/ Bolt on chain hooks #13
Try bolting/weld a piece of 2'x2"x1/4" hollow square tube the entire lenght of your bucket then bolt/weld hooks to that. You will be along time bending that and if you do I want to see a pic of what is left of the FEL. Good luck.
/ Bolt on chain hooks #14
I just cut a piece of 1 1/2" X 1 1/2" X 3/8" angle the width of my bucket and put some slots in it to slip the chain in. I saw where someone else here had done it and it seemed a good way to go. I plan on welding it on in a couple of days. Any one know of a problem with going this route? It would seem like it would stiffen the bucket also.
/ Bolt on chain hooks #15
It sure will stiffen the bucket and I see no problem in doing it that way. I bent the bucket on my JD (which was a 45HP tractor) so I went the square tube route. Bolted every 8" just to get the buckle out of it , then welded the grab hooks on. Put the whole rig out by the highway and it sold in 2 days.
New/Unused ATS Welding Machine (A65583)
New/Unused ATS...
2016 CATERPILLAR TL642D TELESCOPIC FORKLIFT (A65053)
2016 CATERPILLAR...
2018 CATERPILLAR 320GC EXCAVATOR (A60429)
2018 CATERPILLAR...
2006 Peterbilt C15 (A64127)
2006 Peterbilt C15...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
2016 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2016 KENWORTH T680...
