bolt on bucket hooks
/ bolt on bucket hooks #1
greif
kaukauna,wi
Yanmar sx3100
where can I buy bolt on bucket hooks? Tractor supply did not have any. I see "ken bolt on hooks" makes them just wondering if there were some less expensive ones out there
thanks
/ bolt on bucket hooks #3
Question ... Is it tough to drill the bucket for those hooks?
/ bolt on bucket hooks #4
No. Buckets are made from regular mild steel and easy to drill with a good bit. I have two different installation video's posted if you'd like to see for yourself.
/ bolt on bucket hooks #5
its much easier to use channel iron and cut slots for chains and bolt tem on. that way u can use them from either direction.
/ bolt on bucket hooks #6
I drilled my 1/2" holes with a portable battery powered drill and it went pretty quick with a sharp bit. Made pilot holes with a smaller bit first to make sure the holes were centered properly
/ bolt on bucket hooks #7
Depends on the bucket.
If for some reason you've got a reinforced bucket with hardened steel bars (put a grapple on) it might be. But I expect in the sub 100HP tractor world a good cobalt drill, pilot holes, slow drilling, plenty of oil and patience will work through.
/ bolt on bucket hooks #8
Buy a new pilot bit and full size bit before you start to drill. For <$4 make your life easy.
Installation of two Ken's hooks on my B3300SU totaled twenty minutes, with new drill bits.
/ bolt on bucket hooks #9
Kens are awesome, installed mine on my boomer in about an hour with a cordless drill, and they look and work great! Quality all the way
Mark
/ bolt on bucket hooks #10
I wanted clevis hooks without going inside the bucket, so I made these:
I've wrapped chain around the clevis part and used the hooks from behind - works well.
My bolt on midget forks didn't fare too well. I bent one up pretty good trying to cut down a 10" aspen tree with it (accidentally).
/ bolt on bucket hooks #11
I have Ken's hooks on my B2320. You may find cheaper ones, but I doubt you will find better ones. First class stuff.
/ bolt on bucket hooks #12
Same setup as you, and I agree Ken's are hard to beat for the price and quality.
/ bolt on bucket hooks #13
Try Harbor Freight. I think they are on sale for $6.99 each. Work well.
/ bolt on bucket hooks #14
thanks
No affiliation with Ken. I don't even have his hooks as I welded my own but $24 for a quality bolt on hook assembly with all the bolts, instructions etc isn't too steep of a price in my opinion. His stuff is TBN approved with tons of satisfied customers.
HARDEE 300 GALLON PULL TYPE SPRAYER (A64278)
HARDEE 300 GALLON...
2022 CATERPILLAR D1 CRAWLER DOZER (A65053)
2022 CATERPILLAR...
PAIR OF SPAN-ON RIMS (A64278)
PAIR OF SPAN-ON...
CATERPILLAR D8T CRAWLER DOZER (A64279)
CATERPILLAR D8T...
2012 Chevrolet Equinox AWD SUV (A64557)
2012 Chevrolet...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
