Mowing Bolt on blade
/ Bolt on blade #1
cutter49
Conroe,TX
JD ZTRAK 915
After installing new blades I mowed for about an hour and then heard a loud grinding noise. I looked under the deck and saw that the right outside blade was loose. The bolt will not tighten...it just keeps turning. What to do?
/ Bolt on blade #2
you can replace that spindle Or remove it and put a helicoil replacement thread kit in it...
Or drill and tap it to a larger bolt... either of the first two choices will allow you to swap blades with no changes, the last will require changing the bolt hole size in the blade.
/ Bolt on blade
Thanks Kenny, I will give it a go....
/ Bolt on blade #4
Quickest, easiest is just replace the spindle that is if your dealer has it in stock. How old is your mower deck, likely that spindle has lots of wear on it and may fail shortly into the future anyway.
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
2020 Water-Land Dba Continental Trailers Trailer, VIN # 1ZJBU1415LC037150 (A61569)
2020 Water-Land...
58in Hydraulic Side Shift Forks Skid Steer Attachment (A61572)
58in Hydraulic...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2000 Artic Cat ZR600 Limited Edition Snow Mobile (A62613)
2000 Artic Cat...
2014 BOBCAT E42 EXCAVATOR (A64279)
2014 BOBCAT E42...
