Mowing Bolt on blade
/ Bolt on blade #1
cutter49
Conroe,TX
JD ZTRAK 915
After installing new blades I mowed for about an hour and then heard a loud grinding noise. I looked under the deck and saw that the right outside blade was loose. The bolt will not tighten...it just keeps turning. What to do?
/ Bolt on blade #2
you can replace that spindle Or remove it and put a helicoil replacement thread kit in it...
Or drill and tap it to a larger bolt... either of the first two choices will allow you to swap blades with no changes, the last will require changing the bolt hole size in the blade.
/ Bolt on blade
Thanks Kenny, I will give it a go....
/ Bolt on blade #4
Quickest, easiest is just replace the spindle that is if your dealer has it in stock. How old is your mower deck, likely that spindle has lots of wear on it and may fail shortly into the future anyway.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2018 Chevrolet Tahoe SUV (A64194)
2018 Chevrolet...
Kubota MX5400 land mgmt package
Kubota MX5400 land...
