Mowing Bolt on blade
   / Bolt on blade #1
cutter49
Conroe,TX
JD ZTRAK 915
After installing new blades I mowed for about an hour and then heard a loud grinding noise. I looked under the deck and saw that the right outside blade was loose. The bolt will not tighten...it just keeps turning. What to do?
   / Bolt on blade #2
you can replace that spindle Or remove it and put a helicoil replacement thread kit in it...
Or drill and tap it to a larger bolt... either of the first two choices will allow you to swap blades with no changes, the last will require changing the bolt hole size in the blade.
   / Bolt on blade
Thanks Kenny, I will give it a go....
   / Bolt on blade #4
Quickest, easiest is just replace the spindle that is if your dealer has it in stock. How old is your mower deck, likely that spindle has lots of wear on it and may fail shortly into the future anyway.
7021 (A50322)
7021 (A50322)
DEWALT 3400 PSI GAS PRESSURE WASHER (A51248)
DEWALT 3400 PSI...
2011 Mack CHU613 T/A Wet Kit Day Cab Truck Tractor (A51692)
2011 Mack CHU613...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
