bolens peerless transmission harsh launch engagement?
   / bolens peerless transmission harsh launch engagement? #1
tastyratz
I was just given a Bolens g16yt tractor by my wife's father which has probably spent 10 years in the garage and only has about 40 hours or so. It has a B&S 16hp engine and a peerless transmission, great condition. only belts are cracked with age.
One thing I noticed is just how hard the engagement really is. The top inch is where it all happens. It is completely impossible to have a slow engagement - it launches hard and sends you back in your seat. Higher gears mean I am going to lose the chunk of turf I am on.
Looking at the design underneath its belt or no belt so I don't know how much really COULD be done but...
Is there a way to make this a little smoother or adjust it out in any way? Will a new belt make this any better?
   / bolens peerless transmission harsh launch engagement? #2
You may want to make sure that you have the correct belt on it.
I think it is because it feels correctly taught when engaged.
I also just got this thing and gave it a good whirl last weekend - much better than I expected but still a little jumpy.
My original problem was based around starting in 5th from a stop - I had no idea you can shift a peerless while moving which a friend taught me. If I start in a low gear then shift up its not too too bad. I wish it was smoother but thats probably asking too much without a hydro.
   / bolens peerless transmission harsh launch engagement? #4
It's just the nature of the belt idler clutch system. Nowhere near as smooth as a disc clutch. But simple and positive and easy to work on.
My G14 and my 850 are both grabby.
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
2011 Ford F450 Diesel with Just 156638 Miles (A55218)
2011 Ford F450...
2013 CATERPILLAR 312E EXCAVATOR (A51406)
2013 CATERPILLAR...
2017 Harley Davidson Electra Glide (A52377)
2017 Harley...
THOMPSON F4L 1011 PORTABLE DIESEL PUMP (A51406)
THOMPSON F4L 1011...
