bolens 244
/ bolens 244 #1
cking
just bought this 244 diesel bolen's. It run's perficly, the few times I have had it running. But It is hard stating. i have 12 v to the glow plugs and lots of fuel. Any thought? All the fluids need to be filled. I haven't found the filler to the injector yet.
/ bolens 244 #2
Whats the temperature where the tractor is being started?
/ bolens 244
The Temp is around 50.
/ bolens 244 #4
Have you looked at the air filter? Is the glow plug indicator on the dash glowing?
/ bolens 244
Thank you for your intrest. I solved the problem. I noticed that all of fluids where vary low. I found the maintenance chart under the hood and noticed that the injector pump took 30 weight engine oil. The chart also shown where the fill and drain plug were for the injector pump. When looked, I found the injector pump was dry. I fill the pump and the Bolens started right up. And has been starting ever since. :D
213090 (A64276)
213090 (A64276)
NEW ATS Mini Ride on Skid Steer (A62679)
NEW ATS Mini Ride...
Swict 72in Bucket Skid Steer Attachment (A64553)
Swict 72in Bucket...
Heavy Duty Pipe (A62679)
Heavy Duty Pipe...
2006 Kenworth T800 Tandem Dump Truck, VIN # 1NKDLU0X26J147788 (A65563)
2006 Kenworth T800...
UWS TBS-69 Truck Bed Tool Box (A64556)
UWS TBS-69 Truck...
