Bolens 1900 Hydro Eliminator
   / Bolens 1900 Hydro Eliminator #1
DudeJohnDeere
Walworth, NY
1940 Allis Chalmers B, 1992 John Deere 445, 1998 John Deere 855, 2001 John Deere SST18, 2007 John Deere Gator TX and many others at the farm yard
I have replaced the solenoid because it was bad. When I turn the key, nothing happens except for the headlights turning on but when i short out the solenoid the engine turns over. I am just wondering if I have it wired correctly or not.
   / Bolens 1900 Hydro Eliminator #2
Could be the key switch contacts.
Do you have a volt meter to see if you are getting juice into and out from the key switch and on to the solenoid?
You are sure there is no "click" from the solenoid when the key is turned to start?
Many solenoids take juice from the battery wire via a small jumper wire to the solenoid body. then the key switch provides a path to ground, energizing the solenoid.
I bet an internet search for your tractor's wiring diagram would turn up all the details.
Caterpillar 56in Excavator Bucket (A51691)
Caterpillar 56in...
2018 John Deere 325G (A47477)
2018 John Deere...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
Kubota RTV500 (A47384)
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
1269 (A50490)
1269 (A50490)
