Snow Bogging down pushing snow
   / Bogging down pushing snow #1
Kedor
north of Edmonton Alberta
L3130
I have a L3130 HST and during winter conditions, -15 to -35 C , the tractor seems to bog down when pushing a small amount of snow with a back blade. Even after good and warm I have to take it slow to keep moving. I normally have it in M range and only go to low and 4x4 for pushing a round bale. I am assuming the dealer put the correct hydraulic fluid in last service. Any thoughts ?
   / Bogging down pushing snow #2
Does it slow down or does the engine bog down??
   / Bogging down pushing snow #3
I had a L3130 with a six foot sub-frame mounted plow and a six rear blade.You should be plowing in LOW RANGE,I could push three feet of snow no problem,low range and let OFF the HST pedal.Keep the revs up also.
Hello all, thanks for your thoughts. Yes I have fuel additive, usually RPM's are between 1500 and 2000, I will use L range, and the engine has stalled out if I don't let off the Go pedal quick enough. How did you find the 2450 rpms ?
Thanks again.
   / Bogging down pushing snow #8
Agree. Low range and 2000+ rpm.
Third that. Keep the RPM up and the box in low. Snow get's heavy fast. And the cold temps make it harder to pump the hydro fluid.
   / Bogging down pushing snow #9
Wide open, full throttle, let er rip, you won't hurt it if it's warmed up. You will hurt it if you lug it down.
Thanks everyone, more snow is coming so I will let you know how it goes in a couple weeks.
Next step is rear lights ... I have read there are quick connectors under the fender for utility lights?
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
JOHN DEERE 7210R TRACTOR (A54756)
JOHN DEERE 7210R...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
20 LOWBOY BUMPER PULL TRAILER (A55745)
20 LOWBOY BUMPER...
New Holland T2420 (A53317)
New Holland T2420...
2019 Ford F550 Chassis (A55973)
2019 Ford F550...
