Snow Bogging down pushing snow
   / Bogging down pushing snow #11
Thanks everyone, more snow is coming so I will let you know how it goes in a couple weeks.
Next step is rear lights ... I have read there are quick connectors under the fender for utility lights?
Took me awhile to locate mine. They were under the rear fender, in the tail light wiring harness, but doubled over and covered up with tape. Still haven't gotten any female leads that match up yet, but next trip to town maybe.
   / Bogging down pushing snow #12
IF YOU ARE NEW TO HST;the further you push the pedal down (the taller the gearing),LESS PEDAL THE SHORTER THE GEARING,AND THE MORE POWER YOU HAVE.These tractors are not like motor vehicles,let up for more power not push down.
I owned my tractor for a YEAR before I realized this!:)
   / Bogging down pushing snow #13
First ditto above post. Counterintuitive I know but if you start bogging, let OFF the pedal, don't depress further. Second how many hours are on your fuel filter? I just ran into the same thing on my gear tractor. Under heavy load it started bogging down where I didn't think the load was that heavy. Changed the fuel filter and that's all it was. Apparently it was ok under normal fuel demands but when you upped the fuel demand enough fuel couldn't pass through the filter. Same thing would happen to a HST.
Thanks, I had changed the fuel filter last year with the same thought in mind but it didn't make any difference.
   / Bogging down pushing snow #15
Also agree about low range.
Does your B have tach meter?,if so you can gauge/feel comfortable zone for pushing.
By chance did you notice color of exhaust?
Your not only pushing snow but causing drag/fiction from ground as well..little more stress.
   / Bogging down pushing snow #16
I am betting 2450 is just beyond your torque peak (and the rpm setting to achieve 540 rpm at the PTO...good planning)...the advantage of being just over the torque peak (on the "backside") is that if the engine starts to bog, rpms drop and torque increases slightly! neat ...
   / Bogging down pushing snow #17
Maybe you need to change the fuel filter, it will cause the problem you are describing. Cheap check and no harm done by doing it.
Reed
   / Bogging down pushing snow #18
If the filter has wax build up it will do as you describe. Are you by chance still running on summer blend fuel? If so I would add fuel treatment and mix in some winter blend diesel. I always add fuel conditioner to be on the safe side.
   / Bogging down pushing snow #19
Check your air filter also.
   / Bogging down pushing snow #20
YES,
Buddy's blue tractor often slows to near stall as the intake sucks in fine snow and frosts up from time to time.
I am looking into some form of baffle to avoid that issue for him.
Even thinking that in winter he might just as well remove the air filter as in effect the air is relatively clean and dust free. (but knowing him, he would probably forget to re install come spring)
2012 FORD F-650 SUPER DUTY BOX TRUCK (A51243)
2012 FORD F-650...
2015 FORD F450 XL SUPER DUTY SINGLE CAB SERVICE TR (A51243)
2015 FORD F450 XL...
Quick Attach Stump Grinder (A50514)
Quick Attach Stump...
1999 MACK CH613 WATER TRUCK (A50854)
1999 MACK CH613...
2018 GMC Sierra 2500 4x4 Crew Cab Pickup Truck (A50323)
2018 GMC Sierra...
2015 Jeep Compass Latitude SUV (A50324)
2015 Jeep Compass...
