Body Armour
/ Body Armour #1
Green4310TLB
PA
Deere 4310
I knocked out some front lights last summer pushing brush. Then when movig some rocks I had one rock roll off the bucket and dropped on to the hood - plastic hood. You can guess how that worked out. So this winter I am adding some protection to the lights and hood.any pics of similar projects?
/ Body Armour #2
Second picture down:
When John Deere helps Uncle Sam
on edit:
I realize that is probably no help at all. In my twisted little brain, it was the first thing that came to mind. But you have to admit, it IS a cool picture. :D
/ Body Armour #3
on edit:
thanks for the link. It was very cool for a deere fanatic like my self.
/ Body Armour #4
I have seen alot of tractors setup for brush, seems like they either use pipe or 2x2x1/4" square tube frame and expanded metal, couple of pics give the idea of what I have seen
/ Body Armour #6
You can add grill protectors and have seen threads on here of people making them. If you use your tractor at night I would caution you about using any kind of expanded metal in front of the lights. It tends to cut down on the available light along with reflecting back into your eyes. Just my opinion
/ Body Armour #7
For the 4200 - 4400 series of Deere CUT's they offered a hood armor kit. If I recall correctly, it included an upgraded grille guard too.
/ Body Armour #8
Grill guards are easy to make. I like mine better than the store bought. Closer to the grill and slides up & off for easy access.
You can also make a rail or fence across the top of your bucket.
It's important that you watch your bucket as it goes up. Roll the bucket down or forward as it comes up. That next rock may damage something more important than the hood of your tractor.
/ Body Armour #9
I added this to my bucket if this helps. It' removable.
/ Body Armour #11
Here's mine I did last year. I still need to fill in the middle. The chain box real nice and the receiver has come in handy a time or two. I bought the tractor used and the brush guard was a little bent. I welded 3/4"x6" on the sides, back, and bottom to the orginaly brush guard. Then the front is 3/4"x8"
I drilled my holes and bought longer grade 8 bolts.
/ Body Armour #12
No pics, but if you want tremendous stock for light guards, get yourself a shopping cart to cut up. The basket grate material is completely indestructible. I don't know what will help you with dropping boulders onto your hood - boulders are typically quite unforgiving :).
JayC
2019 DRAGON ESP 150BBL ALUMINUM (A60736)
2019 DRAGON ESP...
2019 ATLAS COPCO QAS 25 T4F NB-3 PHASE GENERATOR (A60429)
2019 ATLAS COPCO...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59908)
2016 INTERNATIONAL...
2010 KMC 3376 Peanut Combine (A61307)
2010 KMC 3376...
3015 (A56857)
3015 (A56857)
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
