Bobcat t770 or t870 for mulching?
   / Bobcat t770 or t870 for mulching? #21
I have an M series 750 that I use for mulching. The plastic grates on the side of machine have been replaced several times due to branches smacking them. I have had to replace little things like I always due but for the most part, Bobcat got it right. I am not convinced that glass on the outside of the steel mesh is a good idea, however. I have had a few hard "smacks" and thought I was going to lose the window.
I have my lights covered with expanded metal which helps a lot. Other than lights and dual path cooling covers, there isn't a lot of exposed plastic. These machines are the heaviest yet and built well. I use mine in extremely difficult terrain with heavy attachments and/or handling very large logs and stumps and it does a great job. With that said, there are some after-market options the dealer can install that will help protect the few soft spots like lights, keel access, and there is even a lexan window option.
   / Bobcat t770 or t870 for mulching? #22
Thank you yellow dog! That is all good info. I priced an 870 but am now leaning towards the 770 as I don't think the extra weight is necessary and being 5" narrower is nice for getting into spots. I will use it 50% of the time for mulching and the other time playing around with it. I have 100 acres of field that all the tree lines need to get cleared out from over growth and then the woods will be getting thinned back in 50-100 ft so this should be a good project for it. Besides the normal wear and tear have you had any major issues? Thanks
I own a 870 and love it but if I did it all over again I would definately go with the 770. Number one because its wider than the mulcher and its heavier for transporting than the 770. 870 is also only .5 gallons per minute faster than the 770 which you will not notice.
   / Bobcat t770 or t870 for mulching? #24
Thank you Marc that was the exact answer I was looking for. I didn't think a 14k lb machine with the head was really necessary but wanted real opinions from people in the machine. Greatly appreciated
DOOSAN DL250 LOADER (A51242)
DOOSAN DL250...
John Deere Hsld 2510 H Nh3 Applicator (A50514)
John Deere Hsld...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
2008 FORD F-750XL SUPER DUTY ASPHALT DISTRIBUTOR T (A51243)
2008 FORD F-750XL...
2005 Sterling Single Axle Dump (A47384)
2005 Sterling...
2022 Quick Attach Brush Buster - Heavy-Duty Skid Steer Cutter for Brush and Overgrowth (A52128)
2022 Quick Attach...
