laurencen
Veteran Member
- Joined
- Feb 19, 2007
- Messages
- 1,210
- Location
- saskatchewan Canada
- Tractor
- Bobcat Toolcat 5600T Kioti CK20, Cat D2 dozer, Cat 420 tractor loader, Deer 644E loader, Bobcat E32 mini and Bobcat 590 skidsteer, Toro Groundsmaster 325D
need a bit of information re a 2013 s590, the heater fuse blew on my s590 again, when its cold when else do you need it, lifted the cab, worked the fan with a bit of lube and now it runs, the issue is when the switch is turned to first position there appears to be a fan on the right of the seat, called a lower heater, it will only pulse, on half second and off 4 or 5 seconds, dies this continually, turn it to the second and third position the main fan under seat has 2 speeds.
im sure this lower fan should run continuously, if someone has a 590 could you confirm the lower fan runs just with the start switch turned on without motor running, just in case its designed this way till motor is fired up,
