Bobcat S185 17-07 error code
   / Bobcat S185 17-07 error code #1
KellygC
Bagley, Mn
Bobcat s185
Skidsteer stopped running while idling. Wouldn't restart, "input" displayed in hour meter. Later code of 17-07 came up. Cleaned all grounds, checked main wire harness connections for corrosion(none found). All fuses and relay check out ok. HELP!
   / Bobcat S185 17-07 error code #2
The code is hydraulic lock solenoid open circuit in case you haven't already looked that up somewhere. Hopefully Dennis (SSdoxie) will see your post and give a reply. He's the Bobcat guy on this forum.
   / Bobcat S185 17-07 error code #3
Code means lost communication between main controller and left panel or right Deluxe (keyless panel) if equipped. Communication wires are numbered4 digits and all start with 91. Go to back of each panel and main controller (located in left front fender area). check and wiggle plug connections to see if disappears. If it does remove the connections, clean and apply light coat of dialectic grease.
Also check these wires for continuity of short to ground and/or power. There should be no connection to ground or power with power OFF.
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
1270 (A50490)
1270 (A50490)
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
RoGator 844 sprayer (A50490)
RoGator 844...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
MCELROY COOL PACK 20 (A50854)
MCELROY COOL PACK...
