bobcat s 185 throtle problem
/ bobcat s 185 throtle problem #1
rsabin
bobcat s185
I am thinking this is a simple fix. When I hit bumps with my skid steer the throtle goes down so I have to continually keep pushing up the throle while operating. does anyone know how to fix this. thanks
/ bobcat s 185 throtle problem #2
There is a friction washer in the throttle lever pivot bolt, tighten it up a little.
/ bobcat s 185 throtle problem #3
My T190 had the same problem.
There is three wavy washers that push on the friction disk. Sometimes the washers rust and break. The washers are located in the assembly that includes the throtle handle.
If tightening bolt does not work then:
Lift the cab. Unbolt the assembly and check the washers. Install new if needed, reassemble. You will need to readjust throttle and max speed with the adjustment screws that are part of the throttle lever assembly.
I hope this helps.
Wolverine 72� Skid Steer Screening Bucket (A64047)
Wolverine 72�...
2021 CAM p4EC16W102 16ft. 7000lb Utility Trailer (A64047)
2021 CAM...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
2005 Peterbilt 379 Ext. Day Cab (A62613)
2005 Peterbilt 379...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
John Deere 5090GN (A60462)
John Deere 5090GN...
