bobcat s 185 throtle problem
/ bobcat s 185 throtle problem #1
rsabin
bobcat s185
I am thinking this is a simple fix. When I hit bumps with my skid steer the throtle goes down so I have to continually keep pushing up the throle while operating. does anyone know how to fix this. thanks
/ bobcat s 185 throtle problem #2
There is a friction washer in the throttle lever pivot bolt, tighten it up a little.
/ bobcat s 185 throtle problem #3
My T190 had the same problem.
There is three wavy washers that push on the friction disk. Sometimes the washers rust and break. The washers are located in the assembly that includes the throtle handle.
If tightening bolt does not work then:
Lift the cab. Unbolt the assembly and check the washers. Install new if needed, reassemble. You will need to readjust throttle and max speed with the adjustment screws that are part of the throttle lever assembly.
I hope this helps.
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
2016 Nissan Altima Sedan (A61574)
2016 Nissan Altima...
2023 Boxer 700HDX Compact Skid Steer (A63109)
2023 Boxer 700HDX...
Trailmobile Van Trailer (A63689)
Trailmobile Van...
Willmar 4550 Wrangler Articulating Loader (A63689)
Willmar 4550...
