bobcat s 185 throtle problem
/ bobcat s 185 throtle problem #1
rsabin
bobcat s185
I am thinking this is a simple fix. When I hit bumps with my skid steer the throtle goes down so I have to continually keep pushing up the throle while operating. does anyone know how to fix this. thanks
/ bobcat s 185 throtle problem #2
There is a friction washer in the throttle lever pivot bolt, tighten it up a little.
/ bobcat s 185 throtle problem #3
My T190 had the same problem.
There is three wavy washers that push on the friction disk. Sometimes the washers rust and break. The washers are located in the assembly that includes the throtle handle.
If tightening bolt does not work then:
Lift the cab. Unbolt the assembly and check the washers. Install new if needed, reassemble. You will need to readjust throttle and max speed with the adjustment screws that are part of the throttle lever assembly.
I hope this helps.
2022 Greenworks CU400W Commercial Work Utility Vehicle DEMO UNIT (A61307)
2022 Greenworks...
2008 Dynapac CA150D (A60462)
2008 Dynapac...
1987 GMC WHITE ROLL OFF (INOPERABLE) (A60736)
1987 GMC WHITE...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2019 Sellick S80 (A60462)
2019 Sellick S80...
