Bobcat S 175
/ Bobcat S 175 #1
ty2748
I have a S 175 rubber tire skidsteer. I want to put my steel tracks on it when it's muddy. I need to add spacers to get the tires away from the body so the tracks will fit. The dealer wants $160 for each 11/2" wide spacer. I have to replace the tire lugs with longer ones also.
Does anyone know where I might get these cheaper, maybe a Bobcat junkyard if there is such a place?
Thanks for any help.
/ Bobcat S 175 #2
What brand of tracks are you tyring to use? and what size wheel tires dot you have?
If you have the standard 10.00 X 16.5 tire & wheels spacers are not required to install Bobcat, or most styles of Grouser & Loegering tracks on the S175.
/ Bobcat S 175
Sorry I didn't see your reply. We have the Loegering steel tracks. And I believe we have 10x 16.5 tires. Does your steel tracks fit? We tried but it wouldn't fit, that's why I called the dealer. Maybe I am missing something.
/ Bobcat S 175 #4
PLEASE HELP ME
THIS TROUBLE CODE
H1222
Right thumb switch out of range low
/ Bobcat S 175 #5
PLEASE HELP ME
THIS TROUBLE CODE
H1222
= low voltage to the thumb switch. Controllers sends 5v to the thumb switch with switch at center position feeback volts should be 2.5v +/- .1v
John Deere 7000 Planter (A63109)
John Deere 7000...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A63118)
Dual Tailwheel...
(4) Trail Quest 225/75R/15 Tires and Rims (A64047)
(4) Trail Quest...
2002 CHEVROLET 3500 FLATBED TRUCK (A60430)
2002 CHEVROLET...
2004 Talbert Lowboy Detach Trailer (A64047)
2004 Talbert...
Mini Excavator Attachments (A64047)
Mini Excavator...
