Bobcat S 175
/ Bobcat S 175 #1
ty2748
I have a S 175 rubber tire skidsteer. I want to put my steel tracks on it when it's muddy. I need to add spacers to get the tires away from the body so the tracks will fit. The dealer wants $160 for each 11/2" wide spacer. I have to replace the tire lugs with longer ones also.
Does anyone know where I might get these cheaper, maybe a Bobcat junkyard if there is such a place?
Thanks for any help.
/ Bobcat S 175 #2
What brand of tracks are you tyring to use? and what size wheel tires dot you have?
If you have the standard 10.00 X 16.5 tire & wheels spacers are not required to install Bobcat, or most styles of Grouser & Loegering tracks on the S175.
/ Bobcat S 175
Sorry I didn't see your reply. We have the Loegering steel tracks. And I believe we have 10x 16.5 tires. Does your steel tracks fit? We tried but it wouldn't fit, that's why I called the dealer. Maybe I am missing something.
/ Bobcat S 175 #4
PLEASE HELP ME
THIS TROUBLE CODE
H1222
Right thumb switch out of range low
/ Bobcat S 175 #5
PLEASE HELP ME
THIS TROUBLE CODE
H1222
= low voltage to the thumb switch. Controllers sends 5v to the thumb switch with switch at center position feeback volts should be 2.5v +/- .1v
2003 CASE 70XT SKID STEER (A64279)
2003 CASE 70XT...
Rhino 12ft Blade (A63688)
Rhino 12ft Blade...
UNUSED WOLVERINE RSB84-84" ROCK SCREENING BUCKET (A64281)
UNUSED WOLVERINE...
2007 Generac quiet Source Generator (A61572)
2007 Generac quiet...
Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
Kivel 48in Forks...
2012 Caterpillar 302.5C Mini Excavator (A61572)
2012 Caterpillar...
