Bobcat S 175
   / Bobcat S 175 #1
ty2748
I have a S 175 rubber tire skidsteer. I want to put my steel tracks on it when it's muddy. I need to add spacers to get the tires away from the body so the tracks will fit. The dealer wants $160 for each 11/2" wide spacer. I have to replace the tire lugs with longer ones also.
Does anyone know where I might get these cheaper, maybe a Bobcat junkyard if there is such a place?
Thanks for any help.
   / Bobcat S 175 #2
What brand of tracks are you tyring to use? and what size wheel tires dot you have?
If you have the standard 10.00 X 16.5 tire & wheels spacers are not required to install Bobcat, or most styles of Grouser & Loegering tracks on the S175.
   / Bobcat S 175
Sorry I didn't see your reply. We have the Loegering steel tracks. And I believe we have 10x 16.5 tires. Does your steel tracks fit? We tried but it wouldn't fit, that's why I called the dealer. Maybe I am missing something.
   / Bobcat S 175 #4
PLEASE HELP ME
THIS TROUBLE CODE
H1222
Right thumb switch out of range low
   / Bobcat S 175 #5
PLEASE HELP ME
THIS TROUBLE CODE
H1222
= low voltage to the thumb switch. Controllers sends 5v to the thumb switch with switch at center position feeback volts should be 2.5v +/- .1v
2016 Hurricane Blo-Vac X3 Stand-On Blower (A50324)
2016 Hurricane...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
2013 KENWORTH T800 TRI AXLE CRANE TRUCK (A52472)
2013 KENWORTH T800...
Agro Trend 7' 3PT Snow Blower (A52349)
Agro Trend 7' 3PT...
2004 Range Rover HSE SUV (A51694)
2004 Range Rover...
