Bobcat M700 problems
/ Bobcat M700 problems #1
djw250
Hurricane alley (South Louisiana)
Mahindra 3510
I recently acquired a Melroe Bobcat M700 circa 1974. It runs good, but has problems with the drive. When you first crank it up, it drives and turns pretty good, but after about 5 minutes, the drive gets noisy, jerky, and almost quits completely. If you let it sit for a few minutes, it will go again, but doesn't last long. The lift still works pretty good, and the hydraulic fluid is not hot. It seems like it isn't getting fluid to the drive motors. I'm also not sure how to check the fluid level. There are two 1/2" plugs on the left side between the wheels, one about an inch lower than the other. Could this be the upper and lower level for the fluid? I have been around tractors all my life, but I know nothing about skid steers so any help would be greatly appreciated.
/ Bobcat M700 problems #2
There is a filter under the machine that needs changing. It holds 20 Gallons of Hydro. fluid. Remove the Larger of the two plugs on the left side, if fluid comes out, the fluid is ok, if it doesn"t ,replace plug and remove the small plug and add fluid until it runs out. open back door and the fill tube is on the left side
JOHN DEERE 5403 TRACTOR (A62130)
JOHN DEERE 5403...
2005 Peterbilt 387 with Wet Kit (A63118)
2005 Peterbilt 387...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
2006 GODWIN GHP45KW-RC 45 KW TOWABLE GENERATOR (A63276)
2006 GODWIN...
2013 CARRY-ON TRAILER 14 T/A DOG HOUSE (A63569)
2013 CARRY-ON...
2001 FREIGHTLINER CST120 (A63569)
2001 FREIGHTLINER...
