BobCat F 863
   / BobCat F 863 #1
wlblevin
Bobcat 863 / Ford 1900
:) Members, I am new to your site. I enjoy reading all the comments from all of you. Some of you have very interesting and very helpful information.
I have a problem I need some help on to any knowable member. I have a Bobcat F 863. with a fuel leak. When I pour fuel in the top inlet I have fuel leaking out the bottom. I have been told the tank has a hole in it that causing the leak. Could there be any other problem causing the leak?
   / BobCat F 863
I have a problem I need some help on to any knowable member. I have a Bobcat F 863. with a fuel leak. When I pour fuel in the top inlet I have fuel leaking out the bottom. I have been told the tank has a hole in it that causing the leak. Could there be any other problem causing the leak? I need your help please with this problem. I have been informed if the tank has a hole the engine will have to be removed to replace the fuel tank.
   / BobCat F 863 #5
Pretty sure an 863 is a skid-steer and belongs under the construction equipment.
   / BobCat F 863
:)Thank my equipment the Bobcat F 863 is a skid Steer and it should be posted under Construction Equipment. I am sorry for the problem can some one help me with this please.
   / BobCat F 863 #7
Hi wlblevin,
I'm sorry for that mistake... I moved your thread to the Bobcat Construction Forum. :)
   / BobCat F 863 #8
There is a fuel tank drain. It is accessed from under the machine. There is a retangular plate bolted to the frame, remove the plate to inspect the drain. If it is not leaking out the drain plug then tank has to be removed, yes it sets under the engine so engine has to come out.
   / BobCat F 863
Thanks you for your reply, I have checked the drain Plug and it is tight. I yes it is a hole in the tank. Have you ever replaced a tank before? I am wondering if I can do this job or should I refer this to a dealer? Again thank you for your reply.
2007 Heil Heavy Duty Aluminum Tank Trailer (A56438)
2007 Heil Heavy...
2014 CATERPILLAR 308E2 CR EXCAVATOR (A60429)
2014 CATERPILLAR...
2020 DRAGON ESP...
2017 Ford Fusion (A59814)
2017 Ford Fusion...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
