Bobcat CT5550 suddenly stopped
   / Bobcat CT5550 suddenly stopped #1
Michael Michaelis
Bobcat 5550
Hello I have a Bob cat CT5550 I was using the box blade for about 2 hours with rpm set at 2300, when tractor suddenly stopped, no warning lights sounds prior to shut off. I cant start it now, there is both diesel as well as oil,. The batterie is also sufficient, the tractor turns over however it will not start.
Anyone have some suggestions?
   / Bobcat CT5550 suddenly stopped #2
Sounds like some type of safety sensor. Possibly with the seat?
   / Bobcat CT5550 suddenly stopped #3
If the tractor turns over your safeties are probably all satisfied. Since it died while in use the fuel stop solenoid may be suspect.
Seat sensor did not appear to be damaged and connection was secure, thanks for the thought though.
Ok that makes sense.... I bought the tractor new last year and so i still have warranty on the machine... I will call the company today hopefully it is a quick fix for them to get me back up and running. I will post the results as they come in. thanks for your input
   / Bobcat CT5550 suddenly stopped #7
my 2538 did thisabout a month ago , was brush hogging when it died , turns out the fuel i had just put in was bad. Had to drain entire fuelsystem and replace filters.
2020 DRAGON ESP...
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
2018 Toro Z-Master 6000 Series 74in Zero Turn Commercial Mower (A56857)
2018 Toro Z-Master...
Ford F450 Bucket Truck with Altec AT200A Boom (A56435)
Ford F450 Bucket...
Cushman Electric Cart (A55853)
Cushman Electric...
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
